Visual LISP, AutoLISP and General Customization
atributes to excel
5 REPLIES 5
547 Views, 5 Replies
atributes to excel
hello,
anybody know lisp code's fragment, how exporti info to excel,
such as select line, and export to excel line's length,
but I need only lisp code, no data extraction
5 REPLIES 5
hmsilva
Hi CADGISCODES,
the easiest way is to create a .csv file, then open Excel and import the .csv file as text...
i.e.
(defun c:test (/ *error* ent file fname i line ss)
  (vl-load-com)
  (defun *error* (msg)
    (if	file
      (close file)
    (cond ((not msg))
	  ((member msg '("Function cancelled" "quit / exit abort")))
	  ((princ (strcat "\n** Error: " msg " ** ")))
    );; cond
    (princ)
  );;; *error*
  (if
    (and (not (prompt "\n<<< Select the lines >>>"))
	 (setq ss (ssget '((0 . "LINE"))))
	 (setq fname (getfiled "Enter the file name: "
			       (strcat (getvar "dwgprefix")
				       (vl-filename-base (getvar "dwgname"))
			       "csv"
			       1
    );; and
     (progn
       (setq file (open fname "w"))
       (setq line "Layer\tlength\tStart Point\tEnd Point")
       (write-line line file)
       (repeat (setq i (sslength ss))
	 (setq ent (entget (ssname ss (setq i (1- i)))))
	 (setq
	   line	(strcat
		  (cdr (assoc 8 ent))
		  "\t"
		  (rtos	(distance (cdr (assoc 10 ent)) (cdr (assoc 11 ent)))
			2
			3
		  "\t"
		  (rtos (car (cdr (assoc 10 ent))) 2 3)
		  (rtos (car (cddr (assoc 10 ent))) 2 3)
		  (rtos (car (cdddr (assoc 10 ent))) 2 3)
		  "\t"
		  (rtos (car (cdr (assoc 11 ent))) 2 3)
		  (rtos (car (cddr (assoc 11 ent))) 2 3)
		  (rtos (car (cdddr (assoc 11 ent))) 2 3)
       );; repeat
       (close file)
     );; progn
  );; if
  (*error* nil)
  (princ)
);;; test
HTH
Henrique
in reply to: hmsilva
Thank you hmsilva
Lee_Mac
The code could become slightly more concise through the use of mapcar, e.g.:
(defun c:test ( / *error* des enx ept idx sel spt txt )
    (defun *error* ( msg )
        (if (= 'file (type des)) (close des))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (if (and (setq sel (ssget '((0 . "LINE"))))
             (setq txt (getfiled "Create output file" "" "txt" 1))
        (if (setq des (open txt "w"))
            (progn
                (write-line "Layer\tLength\tSx\tSy\tSz\tEx\tEy\tEz" des)
                (repeat (setq idx (sslength sel))
                    (setq enx (entget (ssname sel (setq idx (1- idx))))
                          spt (cdr (assoc 10 enx))
                          ept (cdr (assoc 11 enx))
                    (write-line
                        (strcat (cdr (assoc 8 enx))
                            (apply 'strcat
                                (mapcar '(lambda ( x ) (strcat "\t" (rtos x 2 3)))
                                    (cons (distance spt ept) (append spt ept))
                        des
                (setq des (close des))
            (princ (strcat "\nUnable to open \"" txt "\" for writing."))
    (princ)
in reply to: Lee_Mac
it's good, thanks ;]
hmsilva
@Anonymous wrote:
Thank you hmsilva
You're welcome, CADGISCODES
More concise, indeed... 🙂
Henrique
”Boost
