ARROW LEADER CONVERT TO LOOP LEADER???
33 REPLIES 33
Message 1 of 34
5020 Views, 33 Replies
Is there a way to have the Arrow leader convert to Loop leader in one click.
Our company standards use diamond tags and sometimes i have to change the arrow to loop by inserting a leader.
33 REPLIES 33
Message 21 of 34
PNG FILE HERE.
PLEASE LET ME KNOW IF THIS IS INFO YOU NEED
THANKS A LOT
Message 22 of 34
Bmp file
Message 23 of 34
for the
standard loop
LEADER Layer: "G-ANNO-TEXT-NOTE-N"
Space: Model space
Handle = 32e7
associative: no
Normal: X= 0'-0" Y= 0'-0" Z= 0'-1"
Horizontal direction: X= 0'-1" Y= 0'-0" Z= 0'-0"
Vertex: X=241'-11 31/64" Y=412'-6 29/64" Z= 0'-0"
Vertex: X=241'-11 55/64" Y=412'-6 47/64" Z= 0'-0"
Vertex: X=242'-0 1/16" Y=412'-6 47/64" Z= 0'-0"
Hook Line: Off
Arrow: On
Path type: Straight
Associated to: MTEXT Handle = 32E8
dimension style: "Aec-Arch-I-96$7"
dimension style overrides:
DIMASZ 3/64"
DIMGAP 1/32"
DIMLDRBLK loop
DIMSCALE 1.000000
DIMTAD 0
DIMTXSTY STANDARDN
DIMTXT 7/64"
for the swaploop
Space: Model space
Handle = 32e9
associative: no
Vertex: X=242'-0 53/64" Y=412'-6 1/16" Z= 0'-0"
Vertex: X=242'-1 13/64" Y=412'-6 17/32" Z= 0'-0"
Vertex: X=242'-1 3/8" Y=412'-6 17/32" Z= 0'-0"
Hook Line: Off
Arrow: On
Path type: Straight
Associated to: MTEXT Handle = 32EA
DIMASZ 1/8"
DIMGAP 1/32"
DIMLDRBLK loop
DIMSCALE 1.000000
DIMTAD 0
DIMTXSTY STANDARDN
DIMTXT 7/64"
Message 24 of 34
Or better yet, post a "small drawing" - preferably zipped - as was requested.
Matt W
"What the flip was Grandma doing at the sand dunes?"
"R. Robert Bell" wrote in message news:5193374@discussion.autodesk.com...
Please post a .png next time (they are much smaller.)
R. Robert Bell
wrote in message news:5193068@discussion.autodesk.com...
I attached three kinds of leaders that we use. I hope I did it right because
this is my first time attaching a picture.
It is a bmp file.
Message 25 of 34
Is this what you need to see???
Message 26 of 34
Yes, thanks!
I don't know how or why your existing dot & loop arrows are doing it, but
the ArrowheadSize fro these is 3/64", but a normal arrow is 1/8". These 2
lisps address specifically these differing sizes:
(defun c:swapdot (/ ent obj)
(vl-load-com)
(princ "\nSelect leader: ")
(if (setq ent (ssget ":S" '((0 . "LEADER"))))
(progn
(setq obj (vlax-ename->vla-object (ssname ent 0)))
(if (= (vla-get-arrowheadtype obj) acArrowDefault)
(progn
(vla-put-arrowheadtype obj acArrowDot)
(vla-put-arrowheadsize obj (/ 3.0 64.0))
(progn
(vla-put-arrowheadtype obj acArrowDefault)
(vla-put-arrowheadsize obj (/ 1.0 8.0))
(princ)
(defun c:swaploop (/ ent obj)
(vl-load-com)
(progn
(progn
(vla-put-arrowheadblock obj "loop")
(progn
(vla-put-arrowheadblock obj "")
(princ)
wrote in message news:5194405@discussion.autodesk.com...
Message 27 of 34
I've officially lost interest in this thread. 😞
Matt W
Message 28 of 34
I will keep this routine so maybe I can figure out something out of this.
Thanks for all
Message 29 of 34
Okay... I lied.
Why not just use the MATCH PROPERTIES button?? (NOW I'm done)
Matt W
Message 30 of 34
caddmandew
Jeff
I wanted to try this routine but what does the "smily frustrated" in code represent?
Jim
Jim Haglund
"It's never too late to have a happy childhood"
Message 31 of 34
Kent1Cooper
in reply to: caddmandew
@caddmandew wrote:
....what does the "smily frustrated" in code represent?
It represents a colon followed by a capital S.  See:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Emoticon-Smiley-to-AutoLISP-Translato...
for a translator, and instructions on how to turn colon-triggered emoticons off when you're signed in.
Kent Cooper, AIA
Message 32 of 34
caddmandew
in reply to: Kent1Cooper
Thank you Kent.
Jim Haglund
Message 33 of 34
caddmandew
It works, yeah.   Here is what happen though...
If the leader is a dot leader and I run the SwapLoop.lsp it turns the leader to a typical closed fill arrow then I select it a second time and it switches to a loop.  Do you know why? and can the code me revide to eliminate that step?
Jim
Jim Haglund
Message 34 of 34
caddmandew
OK I have another question...  Is there a way to make this work with Mleaders?
Thanks in advance
Jim
Jim Haglund
”Boost
