Visual LISP, AutoLISP and General Customization
Arrangement drawings
21 REPLIES 21
Message 1 of 22
622 Views, 21 Replies
Hi guys
At "Mode space" , I have some drawing. maybe is not the same as the size of the drawing frame .
I need to arrange them neatly by drawing No. (eg;1-SS706A-003).
I hope can set Columns
Can set Row spacing and columns spacing too!
I appriciate your help!
For a while before , Mr.hmsilva helped me write a code about "batch insert Xref and Arrangement" (Very grateful)
This have some different, No need insert, The object is not Xref. only need arrangement.
sorry! I don't understand programming, so Need help again !Many thanks!
Drawing frame is not the same ,See Attachments.
21 REPLIES 21
Message 21 of 22
pbejse
@Anonymous wrote:
Thank you very much! pBe, great!
I found several problems .
1)I set Column spacing=100,But actual is 200 ,(2 magnification), I set 200, actual is 400
2) Sort problems, sort by the last three digits of drawing No.
eg.
1-SS706A-001,2-SS706A-002,3-SS706A-003, 1-SS706A-004,1-SS706A-005  this is right.
1-SS706A-001,1-SS706A-004,1-SS706A-0052-SS706A-002,3-SS706A-003  this is wrong.
3) pick point should be at upper left corner, not lower left corner.
1) Column spacing issue [Bug found|Easy Fix]
(setq bp (polar bp 0.0 (+ RSd COd (caaddr (cadr set_)))))
Should be
(setq bp (polar bp 0.0 (+  COd (caaddr (cadr set_)))))
 2).Sort problems < i had no idea you are targetting exclusively the last three digits [Sort by last 3 Digits | Again easy fix]
Change this
(setq Tblocks (vl-sort Tblocks '(lambda (x y)
                                    (< (car x) (car y)))))
To this
(setq _suff   (lambda (str)
                (substr str     (vl-string-position 45 str nil T)
                       '(lambda (x y)
                          (< (_suff (car x)) (_suff (car y))))))
3)  upper left corner, not lower left corner. <----- read comment below
NO, This will remain as bottom left. the math is easier and besides i want it that way :), plus I think i've spend enough time playing around with this code.
HTH
Cheers
Message 22 of 22
in reply to: pbejse
Thank you so much! pBe. nice! cool!
about change "pick basic point" ,if difficult,just let it be.
last request .
I want to have a default value,Not every time input
eg.
Enter Number of Columns<30>:
Enter Row spacing<100>:
Enter Column spacing<100>:
”Boost
