The arealabel lisp (see the code below) works very fine but There is a problem with areas within islands.
I have a drawing with a lot of closed polylines rooms. In those rooms there is sometimes an object like a pilar (island).
the lisp calculate with area. When I use region I have first subtract all the islands. I don't want that manualy. Is there an lisp mehode for this? Like island detection with hatch? By the way... There are no "island into islands" in my drawings.
Sorry for my bad english 😉
gr. Laszlo
;;---------------------=={ Area Label }==---------------------;; ;; ;; ;; Allows the user to label picked areas or objects and ;; ;; either display the area in an ACAD Table (if available), ;; ;; optionally using fields to link area numbers and objects; ;; ;; or write it to file. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Version 1.9 - 29-10-2011 ;; ;;------------------------------------------------------------;; (defun c:AT nil (AreaLabel t)) ;; Areas to Table (defun c:AF nil (AreaLabel nil)) ;; Areas to File ;;------------------------------------------------------------;; (defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t1 t2 tb th ts tx ucsxang ucszdir ) ;;------------------------------------------------------------;; ;; Adjustments ;; ;;------------------------------------------------------------;; (setq h1 "Area Table" ;; Heading t1 "Number" ;; Number Title t2 "Area" ;; Area Title pf "" ;; Number Prefix (optional, "" if none) sf "" ;; Number Suffix (optional, "" if none) ap "" ;; Area Prefix (optional, "" if none) as "" ;; Area Suffix (optional, "" if none) cf 1e-6 ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2) fd t ;; Use fields to link numbers/objects to table (t=yes, nil=no) fo (strcat "%lu6%qf1%ct8[" (rtos cf) "]") ;; Area field formatting ) ;;------------------------------------------------------------;; (defun *error* ( msg ) (if cm (setvar 'CMDECHO cm)) (if el (progn (entdel el) (setq el nil))) (if acdoc (_EndUndo acdoc)) (if (and of (eq 'FILE (type of))) (close of)) (if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell)) (if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n--> Error: " msg)) ) (princ) ) ;;------------------------------------------------------------;; (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc) ) ;;------------------------------------------------------------;; (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc) ) ) ;;------------------------------------------------------------;; (defun _centroid ( space objs / reg cen ) (setq reg (car (vlax-invoke space 'addregion objs)) cen (vlax-get reg 'centroid) ) (vla-delete reg) (trans cen 1 0) ) ;;------------------------------------------------------------;; (defun _text ( space point string height rotation / text ) (setq text (vla-addtext space string (vlax-3D-point point) height)) (vla-put-alignment text acalignmentmiddlecenter) (vla-put-textalignmentpoint text (vlax-3D-point point)) (vla-put-rotation text rotation) text ) ;;------------------------------------------------------------;; (defun _Open ( target / Shell result ) (if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application")) (progn (setq result (and (or (eq 'INT (type target)) (setq target (findfile target))) (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list Shell 'Open target)) ) ) ) ) (vlax-release-object Shell) ) ) result ) ;;------------------------------------------------------------;; (defun _Select ( msg pred func init / e ) (setq pred (eval pred)) (while (progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg)) (cond ( (= 7 (getvar 'ERRNO)) (princ "\nMissed, try again.") ) ( (eq 'STR (type e)) nil ) ( (vl-consp e) (if (and pred (not (pred (setq e (car e))))) (princ "\nInvalid Object Selected.") ) ) ) ) ) e ) ;;------------------------------------------------------------;; (defun _GetObjectID ( doc obj ) (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE")) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false) (itoa (vla-get-Objectid obj)) ) ) ;;------------------------------------------------------------;; (defun _isAnnotative ( style / object annotx ) (and (setq object (tblobjname "STYLE" style)) (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse annotx)))) ) ) ;;------------------------------------------------------------;; (setq acdoc (vla-get-activedocument (vlax-get-acad-object)) acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace)) ucszdir (trans '(0. 0. 1.) 1 0 t) ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir)) ) (_StartUndo acdoc) (setq cm (getvar 'CMDECHO)) (setvar 'CMDECHO 0) (setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0"))))) (setq ts (/ (getvar 'TEXTSIZE) (if (_isAnnotative (getvar 'TEXTSTYLE)) (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0 ) ) ) (cond ( (not (vlax-method-applicable-p acspc 'addtable)) (princ "\n--> Table Objects not Available in this Version.") ) ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER)))))) (princ "\n--> Current Layer Locked.") ) ( (not (setq *al:num (cond ( (getint (strcat "\nSpecify Starting Number <" (itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: " ) ) ) ( *al:num ) ) ) ) ) ( flag (setq th (* 2. (if (zerop (setq th (vla-gettextheight (setq st (vla-item (vla-item (vla-get-dictionaries acdoc) "ACAD_TABLESTYLE" ) (getvar 'CTABLESTYLE) ) ) acdatarow ) ) ) ts (/ th (if (_isAnnotative (vla-gettextstyle st acdatarow)) (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0 ) ) ) ) ) (if (cond ( (progn (initget "Add") (vl-consp (setq pt (getpoint "\nPick Point for Table <Add to Existing>: "))) ) (setq tb (vla-addtable acspc (vlax-3D-point (trans pt 1 0)) 2 2 th (* 0.8 th (max (strlen t1) (strlen t2))) ) ) (vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR))) (vla-settext tb 0 0 h1) (vla-settext tb 1 0 t1) (vla-settext tb 1 1 t2) (while (progn (if om (setq p1 (_Select (strcat "\nSelect Object [Pick] <Exit>: ") '(lambda ( x ) (and (vlax-property-available-p (vlax-ename->vla-object x) 'area) (not (eq "HATCH" (cdr (assoc 0 (entget x))))) (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x)) ) ) entsel '("Pick") ) ) (progn (initget "Object") (setq p1 (getpoint "\nPick Area [Object] <Exit>: "))) ) (cond ( (null p1) (vla-delete tb) ) ( (eq "Pick" p1) (setq om nil) t ) ( (eq "Object" p1) (setq om t) ) ( (eq 'ENAME (type p1)) (setq tx (cons (_text acspc (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1)))) (strcat pf (itoa *al:num) sf) ts ucsxang ) tx ) ) (vla-insertrows tb (setq n 2) th 1) (vla-settext tb n 1 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%" ) (strcat ap (rtos (* cf (vla-get-area p1)) 2) as) ) ) (vla-settext tb n 0 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc (car tx)) ">%).TextString>%" ) (strcat pf (itoa *al:num) sf) ) ) nil ) ( (vl-consp p1) (setq el (entlast)) (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "") (if (not (equal el (setq el (entlast)))) (progn (setq tx (cons (_text acspc (_centroid acspc (list (vlax-ename->vla-object el))) (strcat pf (itoa *al:num) sf) ts ucsxang ) tx ) ) (vla-insertrows tb (setq n 2) th 1) (vla-settext tb n 1 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as)) (vla-settext tb n 0 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc (car tx)) ">%).TextString>%" ) (strcat pf (itoa *al:num) sf) ) ) (redraw el 3) nil ) (vla-delete tb) ) ) ) ) ) (not (vlax-erased-p tb)) ) ( (and (setq tb (_Select "\nSelect Table to Add to: " '(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil ) ) (< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb)))) ) (setq n (1- (vla-get-rows tb)) *al:num (1- *al:num)) ) ) (progn (while (if om (setq p1 (_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ") '(lambda ( x ) (and (vlax-property-available-p (vlax-ename->vla-object x) 'area) (not (eq "HATCH" (cdr (assoc 0 (entget x))))) (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x)) ) ) entsel (list (if tx "Undo Pick" "Pick")) ) ) (progn (initget (if tx "Undo Object" "Object")) (setq p1 (getpoint (strcat "\nPick Area [" (if tx "Undo/" "") "Object] <Exit>: "))) ) ) (cond ( (and tx (eq "Undo" p1)) (if el (progn (entdel el) (setq el nil))) (vla-deleterows tb n 1) (vla-delete (car tx)) (setq n (1- n) tx (cdr tx) *al:num (1- *al:num)) ) ( (eq "Undo" p1) (princ "\n--> Nothing to Undo.") ) ( (eq "Object" p1) (if el (progn (entdel el) (setq el nil))) (setq om t) ) ( (eq "Pick" p1) (setq om nil) ) ( (and om (eq 'ENAME (type p1))) (setq tx (cons (_text acspc (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1)))) (strcat pf (itoa (setq *al:num (1+ *al:num))) sf) ts ucsxang ) tx ) ) (vla-insertrows tb (setq n (1+ n)) th 1) (vla-settext tb n 1 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%" ) (strcat ap (rtos (* cf (vla-get-area p1)) 2) as) ) ) (vla-settext tb n 0 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc (car tx)) ">%).TextString>%" ) (strcat pf (itoa *al:num) sf) ) ) ) ( (vl-consp p1) (if el (progn (entdel el) (setq el nil))) (setq el (entlast)) (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "") (if (not (equal el (setq el (entlast)))) (progn (setq tx (cons (_text acspc (_centroid acspc (list (vlax-ename->vla-object el))) (strcat pf (itoa (setq *al:num (1+ *al:num))) sf) ts ucsxang ) tx ) ) (vla-insertrows tb (setq n (1+ n)) th 1) (vla-settext tb n 1 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as)) (vla-settext tb n 0 (if fd (strcat "%<\\AcObjProp Object(%<\\_ObjId " (_GetObjectID acdoc (car tx)) ">%).TextString>%" ) (strcat pf (itoa *al:num) sf) ) ) (redraw el 3) ) (princ "\n--> Error Retrieving Area.") ) ) ) ) (if el (progn (entdel el) (setq el nil))) ) ) ) ( (and (setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1)) (setq of (open fl "w")) ) (setq *file* (vl-filename-directory fl) de (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t")))) *al:num (1- *al:num) ) (write-line h1 of) (write-line (strcat t1 de t2) of) (while (if om (setq p1 (_Select (strcat "\nSelect Object [Pick] <Exit>: ") '(lambda ( x ) (and (vlax-property-available-p (vlax-ename->vla-object x) 'area) (not (eq "HATCH" (cdr (assoc 0 (entget x))))) (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x)) ) ) entsel '("Pick") ) ) (progn (initget "Object") (setq p1 (getpoint (strcat "\nPick Area [Object] <Exit>: ")))) ) (cond ( (eq "Object" p1) (if el (progn (entdel el) (setq el nil))) (setq om t) ) ( (eq "Pick" p1) (setq om nil) ) ( (eq 'ENAME (type p1)) (_text acspc (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1)))) (strcat pf (itoa (setq *al:num (1+ *al:num))) sf) ts ucsxang ) (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of) ) ( (vl-consp p1) (if el (progn (entdel el) (setq el nil))) (setq el (entlast)) (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "") (if (not (equal el (setq el (entlast)))) (progn (_text acspc (_centroid acspc (list (vlax-ename->vla-object el))) (strcat pf (itoa (setq *al:num (1+ *al:num))) sf) ts ucsxang ) (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of) (redraw el 3) ) (princ "\n--> Error Retrieving Area.") ) ) ) ) (if el (progn (entdel el) (setq el nil))) (setq of (close of)) (_Open (findfile fl)) ) ) (setenv "LMAC_AreaLabel" (if om "1" "0")) (setvar 'CMDECHO cm) (_EndUndo acdoc) (princ) ) ;;------------------------------------------------------------;; (vl-load-com) (princ) (princ "\n:: AreaLabel.lsp | Version 1.9 | © Lee Mac 2011 www.lee-mac.com ::") (princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::") (princ) ;;------------------------------------------------------------;; ;; End of File ;; ;;------------------------------------------------------------;;
Laszlo, change (_centroid) subfunction in AreaLabelV1-9 into this to enable aquiering areas from REGION entities...
(defun _centroid ( space objs / reg cen ) (if (eq (cdr (assoc 0 (entget (vlax-vla-object->ename (car objs))))) "REGION") (setq cen (vlax-get (car objs) 'centroid)) (setq reg (car (vlax-invoke space 'addregion objs)) cen (vlax-get reg 'centroid) ) ) (if reg (vla-delete reg)) (trans cen 1 0) )
And here is my main lisp... You should run it before you start to label REGIONS... Routine will ask for selection of closed LWPOLYLINES and try to make REGIONS with subtracted areas... Your LWPOLYLINES must have only one level deep nesting - so no LWPOLYLINE inside LWPOLYLINE thats already inside LWPOLYLINE... Your drawing must be prepared as you described - main LWPOLYLINES and LWPOLYLINES nested to them (inside them)...
cllwpls2substrregs.lsp
(defun c:cllwpls2substrregs ( / adoc ss i lw ar lwr regl subreg2 reg1sub subss ) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object))) (prompt "\nSelect closed lwpolylines that you want to convert to reduced subtracted regions...") (while (not (setq ss (ssget "_:L" '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))))) (prompt "\nEmpty sel.set... Try again...") ) (repeat (setq i (sslength ss)) (setq lw (ssname ss (setq i (1- i)))) (setq ar (vlax-curve-getarea lw)) (setq lwr (car (vlax-invoke (vla-get-block (vla-get-activelayout adoc)) 'addregion (list (vlax-ename->vla-object lw))))) (setq regl (cons (cons lwr ar) regl)) (entdel lw) ) (setq regl (vl-sort regl '(lambda ( a b ) (> (cdr a) (cdr b))))) (foreach reg1 regl (foreach reg2 (setq regl (cdr regl)) (command "_.SUBTRACT" (ssadd (vlax-vla-object->ename (car reg1))) "" (ssadd (vlax-vla-object->ename (car reg2))) "") (if (> (cdr reg1) (vla-get-area (car reg1))) (setq subreg2 (cons (car reg2) subreg2)) ) (command "_.UNDO" "") ) (setq reg1sub (cons (list (car reg1) subreg2) reg1sub)) (setq subreg2 nil) ) (foreach reg1s reg1sub (setq subss (ssadd)) (foreach subr (cadr reg1s) (ssadd (vlax-vla-object->ename subr) subss) ) (command "_.SUBTRACT" (ssadd (vlax-vla-object->ename (car reg1s))) "" subss "") ) (princ) )
HTH, M.R.
Thank you Marko! It works great!
Only the pick selection from arealabel doesn't work unfortunately with regions I discover.
gr. Laszlo
