Visual LISP, AutoLISP and General Customization
Arc intersection with line in AutoLisp?
22 REPLIES 22
Message 1 of 23
BillZ
1741 Views, 22 Replies
R14 Autolisp:
You can find an intersection of one line with another using the Inters function. Is there an easy way to find the intersection of an Arc with a line? Any formulas?
BillZ
22 REPLIES 22
Message 21 of 23
in reply to: BillZ
Bill,
> BTW: I noticed the last code you posted still only returns one side even
if
> the line intersects twice.
The variable pl either contains (2) point lists when the line intersects
twice, (1) for once or is nil with no intersections. -David
Message 22 of 23
in reply to: BillZ
Well, here is another approach that I wrote back in 1988, it was my first
intents to create a function for line-arc or line-circle intersection
founders.
The one that I use today is way out different, but you can easily changed to
suit your needs.
It will return a list of points even if the line intersect just once you
need to implement the point-is-on-arc method.
Best regards,
Luis Esquivel
ArqCOM Software
www.arqcom.com.mx
Here is de demo...
;;; Usage:
;;; (getlinecir-inters
center> )
;;; Return: List of point or nil
(defun getlinecir-inters (pl1 pl2 cen r / x1 y1 x2 y2 h r2
k yt1 yt2 pt1 pt2 m yk2 xt1 xt2 a b
c z lst1
(setq x1 (car pl1)
y1 (cadr pl1)
x2 (car pl2)
y2 (cadr pl2)
r2 (expt r 2)
h (car cen)
xh2 (expt (- x1 h) 2)
k (cadr cen)
(if (equal x2 x1 0.0001)
(if (>= r2 xh2)
(setq yt1 (+ (expt (- r2 xh2) 0.5) k)
yt2 (- k (expt (- r2 xh2) 0.5))
pt1 (list x1 yt1)
pt2 (list x1 yt2)
(progn
(setq m (/ (- y2 y1) (- x2 x1)))
(if (equal m 0 0.0001)
(if (>= r2 (setq yk2 (expt (- y1 k) 2)))
(setq xt1 (+ (sqrt (- r2 yk2)) h)
xt2 (- h (sqrt (- r2 yk2)))
pt1 (list xt1 y2)
pt2 (list xt2 y2)
(progn
(setq a (+ 1.0 (expt m 2))
b (- (* 2.0 m (- x1 h (* m k))) (* 2.0 y1))
c (+ (expt (+ (* m (- h x1)) y1) 2)
(* (expt m 2) (- (expt k 2) r2))
z (- (expt b 2) (* 4 a c))
(if (equal z 0 0.0001)
(setq z 0)
(if (>= z 0)
(setq yt1 (/ (- (expt z 0.5) b) (* 2.0 a))
yt2 (/ (* -1.0 (+ (expt z 0.5) b)) (* 2.0 a))
xt1 (+ (/ (- yt1 y1) m) x1)
xt2 (+ (/ (- yt2 y1) m) x1)
pt1 (list xt1 yt1)
pt2 (list xt2 yt2)
(if pt1
(setq lst1 (append lst1 (list pt1)))
(if pt2
(setq lst1 (append lst1 (list pt2)))
lst1
Message 23 of 23
BillZ
in reply to: BillZ
Try it again.
BillZ
”Boost
