Visual LISP, AutoLISP and General Customization
Apply Page Setup to Multiple Layouts
5 REPLIES 5
Cinimod89
4236 Views, 5 Replies
Is there any way of applying a new page setup to all the layouts at once?
5 REPLIES 5
phanaem
in reply to: Cinimod89
try this
(defun C:TEST (/ page_setup config l)
  (vl-load-com)
  (or acDoc (setq acDoc (vla-get-activedocument (vlax-get-acad-object))))
  (princ "\n************************************\n")
  (if
    (and
      (> (vla-get-Count (setq page_setup (vla-get-plotconfigurations acDoc))) 0)
      (vlax-for a page_setup (princ (strcat "\n" (car (setq l (cons (vla-get-name a) l))))))
      (not (textscr))
      (member (setq config (getstring "\nSelect page setup: ")) l)
     (vlax-for layout (vla-get-layouts acDoc)
       (if (not (eq (strcase (vla-get-name layout)) "MODEL"))
         (vla-copyfrom layout (vla-item page_setup config))
;;;  (vla-regen acDoc acAllViewPorts)
  (graphscr)
  (princ)
Ajilal.Vijayan
I use the attached lisp file downloaded from theswamp.
Cinimod89
in reply to: phanaem
It loaded fine but I couldn't get past this dialog;
Lee_Mac
Here is another variation, using my List Box function:
(defun c:ps2lay ( / col doc itm lst )
    (setq doc (vla-get-activedocument (vlax-get-acad-object))
          col (vla-get-plotconfigurations doc)
    (cond
        (   (zerop (vla-get-count col))
            (princ "\nNo Page Setups found.")
        (   (null
                (setq itm
                    (LM:listbox "Select Page Setup to Apply"
                        (progn
                            (vlax-for x col (setq lst (cons (vla-get-name x) lst)))
                            (acad_strlsort lst)
                        0
            (princ "\n*Cancel*")
        (   (setq itm (vla-item col (car itm)))
            (vlax-for x (vla-get-layouts doc)
                (if (/= "MODEL" (strcase (vla-get-name x)))
                    (vla-copyfrom x itm)
    (princ)
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
    (cond
        (   (not
                (and
                    (setq tmp (vl-filename-mktemp nil nil ".dcl"))
                    (setq des (open tmp "w"))
                    (write-line
                        (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
                    (< 0 (setq dch (load_dialog tmp)))
                    (new_dialog "listbox" dch)
            (prompt "\nError Loading List Box Dialog.")
        (   t
            (start_list "list")
            (foreach itm lst (add_list itm))
            (end_list)
            (setq rtn (set_tile "list" "0"))
            (action_tile "list" "(setq rtn $value)")
            (setq rtn
                (if (= 1 (start_dialog))
                    (if (= 2 (logand 2 bit))
                        (read (strcat "(" rtn ")"))
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
        (vl-file-delete tmp)
    rtn
(vl-load-com) (princ)
phanaem
Replace (getstring "\nSelect page setup: ") with (getstring T "\nSelect page setup: ").
You have to manualy enter the name of page setup, exactly like it apears in list, so Lee's dialog box is more friendly.
”Boost
