Visual LISP, AutoLISP and General Customization
APPLOAD Fails - not being loaded
0 REPLIES 0
Message 1 of 1
whitney_jeff
282 Views, 0 Replies
AutoCAD 2011 - the appload.arx is not being loaded when acad2011 is started.  The appload.arx and apploadres.dll are in the correct foldet (AutoCAD 2011).  Just to make sure, I added AutoCAD 2011 to the search path, still does not load.  Since appload does not load, none of the files in the startup suite are loaded.  I am sure that the appload was loaded 2 weeks ago - this is a user's compuiter and not mine (I have been comparing files and folders to mine as a base, since it works on mine).
I think I have run into this before but cannot remember how it was fixed or if I did indeed have this issue.
0 REPLIES 0
”Boost
