Member
odin
Message 1 of 7 (149 Views)
Apperaring Warning error
149 Views, 6 Replies
05-28-2012 10:20 PM
I have made a block with consist of shape drawing and some attribute data that must specified when the block inserted. my question is, how to make "warning error input" appear if mistake input occurs? thanks to anyone could help me :smileyhappy:
Distinguished Mentor
_Tharwat
Message 2 of 7 (146 Views)
Re: Apperaring Warning error
05-28-2012 10:35 PM in reply to: odin
e.g.
(if (eq <inputs) correct)
    (do this)
    (otherwise print a message of your desire )
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Moshe-A
Message 3 of 7 (123 Views)
05-29-2012 09:56 AM in reply to: odin
Odin,
that's depands on what input the user should be enter...if the attribute is expecting a numeric value?
then you can do somthing like this?:
(setq real_value (getreal "\nEnter real value: ")) ; require a value from 0 to 100
(if (and
         (>= real_value 0)
         (<= real_value 100)
   (do_insert_block)
   (prompt "\n*invalid value*")
if the attribute is expecting a string value (like a key option)?
then you can do somthing like that:
(initget "Red Yellow Green Cyan") ; note the capital letter at start of each key word option
(setq color (getkword "\nChange color -> Red/Yellow/Green/Cyan: "))
the user can enter only R for Red, Y for Yellow (like any other key option in any other
standard AutoCAD Command
if user misses to specify the right key option? then autolisp it self will alert him and continue
to pause until the right value (allowed) is given.
Cheers,
Moshe
Kent1Cooper
Message 4 of 7 (117 Views)
05-29-2012 10:37 AM in reply to: Moshe-A
Moshe-A wrote:
....if the attribute is expecting a numeric value?
(if (and
         (>= real_value 0)
         (<= real_value 100)
   (do_insert_block)
Two refinements I would suggest:
Numerical value comparison functions can take more than two arguments.  So in place of
(and
  (>= real_value 0)
  (<= real_value 100)
you can do simply:
(<= 0 real_value 100)
And if you format it something like this:
(while
  (not
      0 ; minimum allowable value
      100 ; maximum allowable value
  ); not
  (prompt "\nYou must give a value between 0 and 100.")
); while
.... go on with insertion, feeding values in where Attribute prompts occur ....
it will work like the (initget)/(getkword) approach, in that it will keep asking for input until a valid value is supplied, rather than just taking one input, and if it's wrong, putting up a message and stopping.
Kent Cooper
Member
odin
Message 5 of 7 (97 Views)
05-29-2012 10:11 PM in reply to: odin
Thanks a lot, I'll try to use it in my drawing, it will usefull for me Rrgard, Odin
Member
odin
Message 6 of 7 (91 Views)
05-29-2012 11:08 PM in reply to: _Tharwat
Thanks a lot it will help full
Member
odin
Message 7 of 7 (90 Views)
05-29-2012 11:10 PM in reply to: Kent1Cooper
Thanks a lot It will help full for me
