Anyone have thoughts on how to process "best fit" hole patterns on oddly shaped parts?
5 REPLIES 5
266 Views, 5 Replies
I am thinking about some different methods, but maybe a fresh approach could
get me off center!
Thanks, I will also share final approach when done.... 🙂
Bob Q
Pentium 4 3.33 GHz
1GB RAM
XP Pro SP2
ATI Mobility Radeon 9000 IGP graphics.....
MDT 2004DX
5 REPLIES 5
stevor
1. Compare areas.
2. Divide into segments and sum the offset distances, or use any statistical evaluation method.
S
Thanks Stevor 🙂
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
1.
Compare areas. 2. Divide into segments and sum the offset distances, or use
I am going to try to create multiple hole
locations, then check the total distance between them....
Hopefully the hole pattern with the greatest total
distance will work.... 🙂
Thanks Stevor 🙂
1.
Create a hammer.dwg
Then use on part...
"Bob Quinn" wrote in message
news:6142434@discussion.autodesk.com...
get me off center!
Bob Q
Pentium 4 3.33 GHz
1GB RAM
XP Pro SP2
MDT 2004DX
stevor
You did not state the type of entity that represents the hole like shapes.
If periodic points along the perimeter of the 'holes' can be derived from the objects,
then you can also derive a list of centers from the intercepts of the normals at the midpoints on two consecutive cords.
A pseudo center can be made from the centers list by averaging or by some statistical method, and a a radius likewise.
For design purposes, the center location and radii dimensions would be standardized.
S
”Boost
