I wrote a lisp routine to align text vertically and change the Justification at the same time. It works fine for Plain text but when I try it on Mtext It doesn't change group code 71 or group code 10 with ENTMOD. Is there a way to do this?
Thanks in advance.
Hi.
If you put the entmoding codes after eachother into your codes , it would do only the first entmod only , so this should
do the trick .
(defun c:Test (/ e) (defun _Entmoding (selectionset key value / i sn e) ;;; Tharwat 01 . January 2012 ;;; ;;; This sub-routine would entmod ;;; ;;; any entity according to keys and values ;;; (if (eq (type selectionset) 'PICKSET) (repeat (setq i (sslength selectionset)) (setq sn (ssname selectionset (setq i (1- i)))) (setq e (entget sn)) (entmod (subst (cons key value) (assoc key e) e ) ) ) ) ) (if (setq e (ssget "_:L" '((0 . "MTEXT")))) (progn (_Entmoding e 71 1) (_Entmoding e 10 '(0. 0. 0.)) ) ) (princ) )
Tharwat
@GeeHaa wrote:Hi,
Thanks in advance.
Easy way, YES. VL-codes. Theres also a way to do it with Entmod,
Post your code so we can have a look-see.
(DEFUN C:alignV2 (/ Elist e2 e3 e4 ETYPE cnt vert XDST YDST p3 p2 p1 TB Csnap *ERROR* ) ;;;THIS PROGRAM ALIGNS TEXT VERTICALLLY CHANGING THE JUSTIFICATION ;;;03-16-1999 (vl-load-com) (setq Csnap (getvar "snapmode")) (setvar "snapmode" 0) (if (< (getvar "OSMODE") 16383) (setvar "OSMODE" (+ (getvar "OSMODE") 16384)) ) (defun *ERROR* (msg) (setvar "snapmode" Csnap) (setvar "osmode" (- (getvar "osmode") 16384)) (princ (strcat "error " msg)) (princ) ) (defun getbbox (ename / pts) (vla-getboundingbox (vlax-ename->vla-object ename) 'LL 'UR) (setq pts (mapcar 'vlax-safearray->list (list LL UR))) ) (defun getattach (just curAttach) (setq Justidx (list (list 1 2 3) (list 4 5 6) (list 7 8 9))) (foreach justGrp justIdx (if (member curAttach justGrp) (setq newJust (nth just justGrp)) ) ) newJust ) (princ "\nSelect Text item then text to align vertically with it" ) (setq e1 (ssget)) (setq pts (getbbox (ssname e1 0))) (setq pLL (car pts) pUR (cadr pts) ) (setq pJust (getpoint "\nEnter point for justification ")) (setq cnt 1) (cond ((< (car pJust) (car pLL)) (setq just 0) (setq alignPx (car pll)) ) ((and (> (car pJust) (car pLL)) (< (car pJust) (car pUR))) (setq Just 1) (setq alignPx (+ (car pLL) (/ (- (car pUR) (car pLL)) 2.0))) ) ((> (car pJust) (car pUR)) (setq just 2) (setq alignPx (car pUR)) ) ) (setq cnt 0) (repeat (sslength e1) (setq e2 (ssname e1 cnt)) (setq e3 (entget e2)) (IF (OR (= (setq ETYPE (cdr (assoc 0 E3))) "TEXT") (= (setq ETYPE (cdr (assoc 0 E3))) "MTEXT") ) (PROGN (IF (= ETYPE "TEXT") (PROGN (setq vert 73) (setq vertIdx (cdr (assoc vert e3))) (setq P1 (cdr (assoc 10 E3))) (if (and (= 0 (cdr (assoc 73 e3))) (= 0 (cdr (assoc 73 e3)))) (PROGN (setq assocNum 10) ) (progn (setq assocNum 11) ;else ) ) (setq p2 (cdr (assoc assocNum e3))) (setq P3 (list alignPx (cadr P2))) (setq E3 (subst (cons 72 just) (assoc 72 E3) E3)) (setq E3 (subst (cons vert vertIdx) (assoc vert E3) E3)) (if (and (= 0 just) (= 0 (cdr (assoc vert e3)))) (setq E3 (subst (cons 10 P3) (assoc 10 E3) E3)) (setq E3 (subst (cons 11 P3) (assoc 11 E3) E3)) ) (entmod E3) (entupd e2) ) ) (IF (= ETYPE "MTEXT") (PROGN (setq vert 71) (setq vertIdx (getattach just (cdr (assoc vert e3)))) (setq p2 (cdr (assoc 10 e3))) (setq P3 (list alignPx (cadr P2))) (setq E3 (subst (cons 10 P3) (assoc 10 E3) E3)) (setq E3 (subst (cons vert vertIdx) (assoc vert E3) E3)) (entmod E3) (entupd E2) ) ) ) ) (setq cnt (1+ cnt)) ) (setvar "snapmode" Csnap) (setvar "osmode" (- (getvar "osmode") 16384)) (princ) )
Using the VL functions works
I put these lines in instead of the subst and entmod functions and it works.
(setq vlEnt (vlax-ename->vla-object e2))
(vlax-put-property vlEnt 'attachmentpoint vertIdx)
(vlax-put-property vlEnt 'insertionpoint (vlax-3d-point p3))
I still don't know why entmod doesn't
Thanks very Much.
@GeeHaa wrote:Using the VL functions works
Thanks very Much.
Glad that helps.
I tried your code just, nowunless you're using annotative textstyle , it appears to be working fine here. when and what condition when your code bombs?
Anyhoo. no need to ponder on it now then.
