Active Contributor
GuitarLover
Message 1 of 7 (356 Views)
ADOLISP ADO-AttDB returns Can't connect dialog
356 Views, 6 Replies
07-14-2011 02:09 PM
** I originally posted this in the ASE forum, but moved it here since it applies to AutoLisp.
I am trying out ADOLISP. When I enter ADO-AttDB?, a dialog says:
Can't connect the the database using "Provider=MSDASQL;Driver={Microsoft Access Driver (*.mdb)};DBQ=C:\InstallCAD\acad\Databases\ADO Lisp\AttDB Test.mdb"
logging as "admin" with password ""?
I checked to make sure the .mdb file exists in said folder.
Maybe the SQL driver? If so, how do I check that?
I'm on XP SP3, autocad 2004
Please help.
Chris
ADN Support Specialist
Marat.Mirgaleev
Message 2 of 7 (336 Views)
Re: ADOLISP ADO-AttDB returns Can't connect dialog
07-20-2011 09:41 AM in reply to: GuitarLover
Hi Chris,
   I'd suggest to try the same connection string from a different program, like Excel etc.
   If you system is 64-bit, it also can be the source of the problem.
Marat Mirgaleev
Developer Technical Services
Autodesk Developer Network
Active Contributor
GuitarLover
Message 3 of 7 (327 Views)
07-20-2011 12:00 PM in reply to: Marat.Mirgaleev
Marat,
Thanks for your response.
I am using 32-bit XP SP3.
I am a total noob. If I do your suggestion in Excel, can I use vba? Would you give me a quick example?
Also, what will this step tell me?
Valued Mentor
gasty1001
Message 4 of 7 (324 Views)
07-20-2011 02:02 PM in reply to: GuitarLover
Check this web site: http://www.connectionstrings.com/
-gnb
southie
Message 5 of 7 (313 Views)
07-20-2011 05:55 PM in reply to: GuitarLover
This works for me.
(setq fnd (getfiled "Select a Database" "c:\\yourdatabasepath\\" "mdb" 0));choose your .mdb file
(setq ConnectString (strcat "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" fnd ";Persist Security Info=False"))
hth
Southie
Marat.Mirgaleev
Message 6 of 7 (303 Views)
07-21-2011 02:00 AM in reply to: GuitarLover
   Yes, VBA would be fine.
   If the connection string does NOT work in Excel, that means that you have a problem: - with the connection string itself; - or with your database file; - or with the database driver.
   If it works in Excel, it will mean that the problem is with AutoCAD and Lisp.
Marat Mirgaleev
Distinguished Contributor
petervose
Message 7 of 7 (271 Views)
08-09-2011 02:03 AM in reply to: Marat.Mirgaleev
Could it simply be that you need the double-backslash in your file path?
ie.     C:\\InstallCAD\\acad\\Databases\\ADO Lisp\\AttDB Test.mdb
