Visual LISP, AutoLISP and General Customization
Adding Xdata From Slected Mtext or Text
3 REPLIES 3
karunakaran1991
988 Views, 3 Replies
I am creating lisp routine and the work is to selected Mtext or text and the corresponding content is to be added as Xdata to the selected entity.
(defun C:addxdata()
(setq a(entget(car(entsel"\nSelect Text: "))))
(setq Xdata1 (cdr (assoc 1 a))) (princ Xdata1)
(setq b(entget(car(entsel"\nSelect Text: "))))
(setq Xdata2 (cdr (assoc 1 b))) (princ Xdata2)
(regapp "Test_Xdata" )
(setq oldlist (entget (car (entsel))))
(setq thedata '((-3 ("Test_Xdata" (1000 . Xdata1) (1000 . Xdata2 ))))) )
Then I used list Xdata option available under Express tool Tab (Auto Cad 2014).
I didn't find any Xdata Attached with it.
After Adding the Xdata, I wanna export to Excel.
For the Excel Conversion, Lisp is working good.
I guess the Problem is in the following line,
Though the value stored in variable it is not working properly.
Tags (1)
3 REPLIES 3
hmsilva
in reply to: karunakaran1991
Try
(defun C:addxdata ( / a adata b bdata c newlist oldlist thedata Xdata1 Xdata2)
  (if (and (setq a (car (entsel "\nSelect Text: ")))
           (setq adata (entget a))
           (wcmatch (cdr (assoc 0 adata)) "TEXT,MTEXT")
           (setq Xdata1 (cdr (assoc 1 adata)))
           (princ Xdata1)
           (setq b (car (entsel "\nSelect Text: ")))
           (setq bdata (entget b))
           (wcmatch (cdr (assoc 0 bdata)) "TEXT,MTEXT")
           (setq Xdata2 (cdr (assoc 1 bdata)))
           (princ Xdata2)
           (setq c (car (entsel "\nSelect object to attach xdata...")))
           (setq oldlist (entget c))
    (progn
      (regapp "Test_Xdata")
      (setq thedata (list (list -3
                                (list "Test_Xdata"
                                      (cons 1000 Xdata1)
                                      (cons 1000 Xdata2)
      (setq newlist (append oldlist thedata))
      (entmod newlist)
  (princ)
From the help files:
String
 1000. Strings in extended data can be up to 255 bytes long (with the 256th byte reserved for the null character).
Henrique
karunakaran1991
in reply to: hmsilva
 I got it where i missed.
Thanks Hmsilva for your precious time
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
