hey i found this lisp and i want to change it so it will work on multiple circles (select objects inside multiple circles)
(defun C:ICS (/ en ss lst ssall tmp head)
;;InSide Contour Select
;;!!!! REQUIRED EXPRESS TOOLS
(vl-load-com)
(if (and (setq en (car (entsel "\nSelect contour: ")))
(wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")
) ;_ end of and
(progn
(setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3))
(setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst))
(while lst
(setq head (car lst)
tmp (cons head tmp)
lst (vl-remove-if
'(lambda (pt) (equal pt head 1e-6))
(cdr lst)
) ;_ end of vl-remove-if
) ;_ end of setq
) ;_ end of while
(setq lst (reverse tmp)) ;_ end of setq
(ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en)))
(command "_.Zoom" "0.95x")
(if (setq ss (ssget "_CP" lst))
(sssetfirst ss ss)
) ;_ end of if
) ;_ end of progn
) ;_ end of if
) ;_ end of defun
(princ "\nType ICS")
hello
just if you want select on one circle it's simple:
(defun C:ICS (/ en ss lst ssall tmp head) ;;InSide Contour Select ;;!!!! REQUIRED EXPRESS TOOLS (vl-load-com) (if (and (setq en (car (entsel "\nSelect contour: "))) ;(wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE") ) ;_ end of and (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda (pt) (equal pt head 1e-6)) (cdr lst) ) ;_ end of vl-remove-if ) ;_ end of setq ) ;_ end of while (setq lst (reverse tmp)) ;_ end of setq (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en))) (command "_.Zoom" "0.95x") (if (setq ss (ssget "_CP" lst)) (sssetfirst ss ss) ) ;_ end of if ) ;_ end of progn ) ;_ end of if ) ;_ end of defun (princ "\nType ICS")
but if you want to select on multiple circle at once time you ca create a repeat loop and use ssget function.
i have 4000 circles that i need to select what inside them.
i want to "select similar" all the circles, and run this lisp so it selects everything inside at once.
possible??
Hi Artur,
the code you have posted, was created by VVA and is destined to select objects 'inside' a *POLYLINE, not a CIRCLE...
possible??
Yes, it will be possible if the boundary CIRCLES have similar properties, as LAYER or COLOR or RADIUS or LINETYPE and unique, not common to the objects to be selected.
Note that using a code to select objects 'inside' 4000 circles will always be an extremely slow code because to select objects 'inside' a circular object we'll have to calculate many points for each CIRCLE to pass the points to the selection method and will be multiplied by 4000, so it will be sloowww...
Henrique
same circles scattered all over the dwg,
how can i do it? the lisp works on one circle but wont let me choose more than one circle
what to change??
If it works, the object is not a CIRCLE, must be a '*POLYLINE'!!!
Post a sample dwg with a few objects (boundaries and objects within the borders) in order we can see the objects properties...
Henrique
Henrique, (ACET-GEOM-OBJECT-POINT-LIST curveename 1e-3) works on any curve among them and on CIRCLES... So taiki's posted revision is fine for a single CIRCLE, and yes for 4000 of them it would be significally slooowww... If we could know proper filter to apply to selection (ssget) function to aquire correct CIRCLES then iteration of sel.set items would be an answer with the rest of code similar to this posted above...
Hi Marko,
I know that 'ACET-GEOM-OBJECT-POINT-LIST' works on any curve, but the VVA's original code don't, because it only accepts as valid entity "*POLYLINE", the commented code posted by taiki84 works...
Henrique
layer 4601 small circles on lines (an example)
possible to make the lisp work like the tlen lisp?
you just select all the lines you want to count length and it counts
so possible to make this lisp to work on current selection? i.e. i choose 300 circles or 4000 circles run the lisp and it selects everything inside the circles i chose?
TLEN.LSP - Total LENgth of selected objects
(c) 1998 Tee Square Graphics
(defun C:TLEN (/ ss tl n ent itm obj l)
(setq ss (ssget)
tl 0
n (1- (sslength ss)))
(while (>= n 0)
(setq ent (entget (setq itm (ssname ss n)))
obj (cdr (assoc 0 ent))
l (cond
((= obj "LINE")
(distance (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
((= obj "ARC")
(* (cdr (assoc 40 ent))
(if (minusp (setq l (- (cdr (assoc 51 ent))
(cdr (assoc 50 ent)))))
(+ pi pi l) l)))
((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE")
(= obj "LWPOLYLINE")(= obj "ELLIPSE"))
(command "_.area" "_o" itm)
(getvar "perimeter"))
(T 0))
tl (+ tl l)
n (1- n)))
(alert (strcat "Total length of selected objects is " (rtos tl)))
(princ)
DWG you posted contains blocks that have circle... Those are not CIRCLE entities and now I don't know what would be the best way to accomplish your task... Maybe if you just want to select those lines that are passing through those blocks, just make list of points with insertions of all selected blocks and then use (setq ss (ssadd))... (foreach pt ptlst (ssadd (ssname (ssget pt) 0) ss))
to be honest, i have midpoint coodrinates of the lines i want to choose a list of 4000 lines i specificly need to select
any lisp to select by coordinates?
Then, you don't need more than this :
(defun c:selbyptlst ( / ptlst ss ) (setq ptlst '((0.0 0.0 0.0) (1.0 1.0 0.0) (2.0 2.0 0.0))) ;;; => Your 4000 coordinates in variable ptlst (setq ss (ssadd)) (foreach pt ptlst (ssadd (ssname (ssget "_C" pt pt) 0) ss) ) (sssetfirst nil ss) (princ) )
HTH, M.R.
You mean like this? because i did so and it didnt work?
(setq ptlst '((X.X Y.Y Z.Z) (X2.X2 Y2.Y2 Z2.Z2))) ;;; => Your 4000
As a 'demo' and coded from your sample dwg.
If you want the user to select the blocks, remove the "_X" from the first ssget function...
(defun c:demo (/ blk ent i lgt n osm pt ss ss1 tlgt) (vl-load-com) (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "Water_Pipe_section") (66 . 1)))) (progn (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 0) (command "_.zoom" "_E") (command "_.zoom" 0.9) (setq tlgt 0.0) (repeat (setq i (sslength ss)) (setq blk (entget (ssname ss (setq i (1- i)))) pt (cdr (assoc 10 blk)) ) (if (setq ss1 (ssget "_C" pt pt '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength ss1)) (setq ent (ssname ss1 (setq n (1- n))) lgt (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)) tlgt (+ lgt tlgt) ) ) ) ) (setvar 'OSMODE osm) (command "_.zoom" "_P") (command "_.zoom" "_P") (princ (strcat "\nTotal length: " (rtos tlgt))) ) ) (princ) )
Henrique
Let me describe my problem in bigger detail
i have a dwg plan of a whole city and i need to choose specific polylines (only 4000 out of 16000) that i have given coordinates from excel
and cut them to another file.
any lisp to help?
my idea was to spawn circles at the coordinates and do the lisp that chooses everything inside a circle, but i cant select all the circles at once with that lisp
any ideas??
Like Henrique has explained... To select only specific blocks (mid points), remove "_X" from first (ssget) function call...
This is the same code as Henrique offered, only difference is that it should select those entities that pass through those blocks (mid points) so you can cut them to another file...
(defun c:demo ( / blk ent i n osm pt s ss ss1 ) (setq s (ssadd)) (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "Water_Pipe_section") (66 . 1)))) (progn (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 0) (command "_.zoom" "_E") (command "_.zoom" 0.9) (repeat (setq i (sslength ss)) (setq blk (entget (ssname ss (setq i (1- i)))) pt (cdr (assoc 10 blk)) ) (if (setq ss1 (ssget "_C" pt pt)) (repeat (setq n (sslength ss1)) (setq ent (ssname ss1 (setq n (1- n)))) (ssadd ent s) ) ) ) (setvar 'OSMODE osm) (command "_.zoom" "_P") (command "_.zoom" "_P") (sssetfirst nil s) ) ) (princ) )
Regards...
Layer 4601 don't have circles, have blocks...
The 'demo' work like the tlen lisp...
any lisp to help?
any ideas??
Attach a 'real' sample file and if your excel file with the coordinates, only have the desired coordinates, save as .csv file and erase the rest of the coordinates, leaving only a few at the beginning of the file and attach the .csv file also...
'Everithing' is only one 'lwpolyline', correct?
Henrique
1. Post the file that has this list of midpoints, as a start.
2. Sometimes the ssget "c" process needs to make a small box,
ie 2 points, tht straddles the intended point.
