Visual LISP, AutoLISP and General Customization
Adding point as extended data
3 REPLIES 3
329 Views, 3 Replies
Hi all,
I was trying to add a point as extended data to a block.
Therefor i used this data but i get an error every time:
(setq lastent (entget (CAR (entsel))))
(regapp "list")
(setq exdata '((-3
		("list"
		 (1011 . 3277.82)
		 (1021 . 5782.5)
		 (1031 . 369.5)
(setq newent
       (append lastent exdata)
(entmod newent)
Can somebody tell me what went rong?
Regards
Thomas
3 REPLIES 3
dgorsman
Assuming the DXF codes are capable of supporting double value types, you aren't creating a list of dotted pairs.  I think the XDATA identifier also needs a DXF code.  You'll need a single-quote on the list if the first element is intended to be the string "list", or use the (list... ) function to construct one on the fly.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Maybe this can help
(setq e (entlast))
(entmod (list (cons -1 e)  '(-3 ("list"  (1011 . 3277.82)  (1021 . 5782.5)  (1031 . 369.5)
southie
I player around a litle whit my function but still can't find the problem.
When i set the list of items i want to add as folows it works perfect
(setq exdata				; Sets the variable
       '((-3
	  ("list"			; exdata equal to the
	   (1041 . 3203.59)		; new extended data—
	   (1041 . 1106.68)
	   (1041 . 0.0)
 But if i want to use group code 1011 (world space position) it doesn't work.
When i want to use it i get the error:
; error: bad DXF group: (-3 ("aansluitingen" (1011 . 3203.59)))
       '((-3
	   (1011 . 3203.59)		; new extended data—
	   (1021 . 1106.68)
	   (1031 . 0.0)
And this is the complete code i use now:
(setq lastent (entget (car (entsel))))	; Gets the association
					; list of definition data
					; for the last entity.
(regapp "list")				; Registers the
					; application name.
       '((-3
	   (1021 . 1106.68)
	   (1031 . 0.0)
	)				; in this case, a text
)					; string.
(setq newent
)					; Appends new data list to
					; entity's list.
(entmod newent)				; Modifies the entity with the
new
					; definition data.
Regards
Thomas
P.S.: thanks for olready looking at the problem
”Boost
