Visual LISP, AutoLISP and General Customization
adding a text to selected texts
6 REPLIES 6
aqdam1978
492 Views, 6 Replies
I need a LISP program to add a text given by user to all selected text.
in other words:
1- user selects some texts.
2- user give a text to program.
3- Program added this text to all selected text.
selected text: text1, text2, text3,text4,....,textn
given text by user: _xyz
Result:
text1_xyz, text2_xyz, text3_xyz,text4_xyz,....,textn_xyz
Can anybody help me?
Thanks.
6 REPLIES 6
hmsilva
in reply to: aqdam1978
maybe something like
(defun c:test	(/ ss nstr str itm obj)
    (vl-load-com)
    (prompt "\nSelect texts to adda string: ")
    (if	(and (setq ss (ssget "_:L" '((0 . "TEXT"))))
	     (setq
	       nstr (getstring "\nEnter the string to add to the text: ")
      (repeat (setq itm (sslength ss))
	(setq
	  obj (vlax-ename->vla-object (ssname ss (setq itm (1- itm))))
	(setq str (vla-get-textstring obj))
	(vla-put-textstring obj (strcat str nstr))
      );; repeat
    );; if
    (princ)
hope that helps
Henrique
3wood
You can try ALTEXT.vlx,
just set "_xyz" as suffix.
aqdam1978
in reply to: hmsilva
Hi hmsilva,
Your program is GREAT.
Thank you very much.
aqdam1978
in reply to: 3wood
Hi 3wood,
where can I find the "ALTEXT.vlx" file.
is this file free or I should buy it?
hmsilva
You're welcome,  aqdam1978
pbejse
anothter
(defun c:Asuf ( / suf ss i e st l)
(while (not (progn
  		(setq suf (getstring T "\nEnter string to add: "))
  		(if ( eq suf  "") nil suf ))))
(if (setq ss (ssget "_X" '((0 . "*TEXT"))))
	(repeat (setq i (sslength ss))
		(setq e (entget (ssname ss (setq i (1- i))))
                      st (cdr (assoc 1 e))
          	      l (assoc -1 e))
          	 (entmod (list (cons 1 (strcat st suf)) l)))
	)(princ)
HTH
”Boost
