adding a regapp to an existing xdata entry
5 REPLIES 5
nunleym
540 Views, 5 Replies
First time posting, just wanted to thank everyone for all the data up here i have usually been able to find what i need without having to ask, but this time i am truely stumped.
I am trying to add an additional regapp and data to an entity that already has xdata.
(entmod
  (subst (append (assoc -3 (entget #bomitem '("*")))  (list (list "GN_NOTE" '(1002 "{")(cons 1005 (cdr (assoc 5 (entget #last_note_name))))'(1002 "}"))))
         );subst
  );entmod
I keep getting "; error: bad DXF group:" I've tried setting it to a variable and trying entmod also
any assistance would be greatly appriciated
Thanks in advance for your help!
5 REPLIES 5
hmsilva
in reply to: nunleym
Welcome to the Autodesk Discussion Community, nunleym!
If your goal is to add 'an additional regapp' try
(regapp "GN_NOTE")
(entmod (append (entget #bomitem) (list (list -3 (list "GN_NOTE" (cons 1005 (cdr (assoc 5 (entget #last_note_name)))))))))
Hope that helps
Henrique
nunleym
in reply to: hmsilva
Thanks for the reply silva,
The result I am looking for is something like this:
(-3 ("ITEM" (1002 "{") (1000 . "29336") (1002 "}")) ("GN_NOTE" (1002 "{") (1005 . "8668") (1002 "}")))
I am looking to add additional xdata to an entity that already has a regapp and xdata attached.
Thank you
hmsilva
Your code, revised...
You did miss two dots..
(entmod
  (subst (append (assoc -3 (entget #bomitem '("*")))  (list (list "GN_NOTE" '(1002 . "{")(cons 1005 (cdr (assoc 5 (entget #last_note_name))))'(1002 . "}"))))
         );subst
  );entmod
Hope that helps
Henrique
nunleym
that was it thank you so much
You are the grooviest
Thank you
hmsilva
You're welcome, nunleym
Glad I could help
Henrique
”Boost
