MG,
Good, looks like you question has been answered.
Color and linetype DFX's are not part of the entity definition when these are bylayer conditions. When you expand your menu system, you might encounter this problem down the road...
Check to see if the DFX's exist and if so, construct the new value, otherwise append the entity.
When you want to restore back to bylayer, I have found that using the CHPROP command does this most efficiently.
Good Luck!
Scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
