Hey all.
I've managed to retrieve the important points of a leader with the following code:
(setq edata (entget (entlast)))
(setq leader? (cdr (assoc 0 edata)))
(cond
((= leader? "LEADER")())
(T(setq edata (cdr (entget (car (entsel "\nPick a leader: "))))))
(setq edata10 (member (assoc 10 edata) edata))
(setq listlength (length edata10))
(setq WCSLastPoint (cdr (nth (- listlength 6) edata10))); last point in WCS
(setq UCSLastPoint (trans WCSLastPoint 0 1))
(setq WCS2ndLastPoint (cdr (nth (- listlength 7) edata10))); second last point in WCS
(setq UCS2ndLastPoint (trans WCS2ndLastPoint 0 1))
(setq lastpointX (car UCSLastPoint))
(setq 2ndlastpointX (car UCS2ndLastPoint))
(cond
((> lastpointX 2ndlastpointX)(setq justify "Left"))
((< lastpointX 2ndlastpointX)(setq justify "Right"))
(T(Alert "The last segment of the leader is vertical"))
What I'd like to do is add a horizontal segment of a known length to the leader, obviously based on the last point. I have to assume that the user is in the appropriate UCS for this, but I can trouble shoot for that later.
What do I do here? subst old list iwth a new list and apply it to the entity somehow?
Thanks much
KP
@kpennell wrote:Hey all.
Thanks much
KP
KP
would this be right after you create the leader?
or
Modify an existing leader?
Hey pbejse,
Yeah I aleady have the entity and the last two points of the leader, indicating which way the horizontal line should go, if it's justified right or left. I did notice in your post though, that the code I posted did not show up, but other portions of my post did (something weird?).
Like I said, I'd like to take an existing leader and add a horizontal line segment (add an assoc 10 list) of a known length to the leader that was last created or user-selected. I'm not sure how to substitute the dxf codes.
KP
@kpennell wrote:Hey pbejse,
KP
I dont have cad with me right now KP. I personally use vl-put-coordinates , another alternative is to recreate the leader via entmake. I'll get back to you after i get my hands on Acad.
Yeah, I've found some posts regarding the vl-put-coordinates, but I don't understand the syntax, though I think it's the best way to go to modify something existing, rather than deleting it and re-creating it.
Thanks for your attention on this. I look forward to it.
KP
Alright KP here we go.
What is the length of the landing? are the existing leader entities only have tow points?
3/32 is the landing length, and no, it's not always two points. That's why in the code I do have developed, it's getting the last and second last point to determine the proper justification.
KP
@kpennell wrote:3/32 is the landing length, and no, it's not always two points. That's why in the code I do have developed, it's getting the last and second last point to determine the proper justification.
KP
I see, what would happen if the leader is "VERTICAL" jsut show an alert box?
BTW: if it has a landing but longer than 3/32 , what then?
Since you have not answered yet
try his for now, its a bit messy though
(defun c:Landing (/ ss e pts)
(vl-load-com)
(setq ss (ssget ":L" '((0 . "LEADER"))))
(repeat (sslength ss)
(setq e (ssname ss 0))
(setq pts (mapcar 'cdr
(vl-remove-if-not
'(lambda (x) (= (car x) 10))
(entget e))))
(vlax-put
(vlax-ename->vla-object e)
'coordinates
(apply
'append
(list
(vlax-get
e)
'Coordinates)
(polar
(last pts)
(if (> (caar pts)
(car (last pts)))
pi
0.0)
0.09375))))
(ssdel e ss)
(princ)
Not sure if i got the correct landing length. try it and tell me what you think. then i'll get back to you tomorrow.
HTH
works great. tried it with several configurations, and worked.
huge thanks mate.
as for the tidiness, what would you do? WIsh I knew more about vl syntax.
KP
@kpennell wrote:works great. tried it with several configurations, and worked.
huge thanks mate.
KP
You are welocme KP. Glad i could help.
@kpennell wrote:as for the tidiness, what would you do? WIsh I knew more about vl syntax.
Nothing really, jus the usual bells and whistles.Last night i wrote the code in haste.
Anyhoo, here's a cleaner version (not much different though)
(vl-load-com)
(if (setq ss (ssget ":L" '((0 . "LEADER"))))
(vl-remove-if-not
(entget e))))
(vlax-put
'coordinates
(apply
'append
(list
(apply 'append pts)
(polar
(last pts)
(if (> (caar pts)
(car (last pts)))
pi
0.0)
0.09375))))
(ssdel e ss)
)(princ "\nNo Leader entity selected"))
(princ)
Cheers KP
