@ebarlevi wrote:How can I add\remover layers from a layer filter via VLISP?
I'm not sure if this is really something you would want to do. The layers displayed in the layer filter are based on the filter definition. My GUESS is that forcibly removing a layer from the layer properties filter (if possible) will not keep the layer from re-entering the filter results unless you change the filter definition.
Basically, any layer which meet the criteria of the layer properties filter definition should be displayed in the filter. You may consider modifying the filter definition.
Perhaps you meant for your original question to be: "How can I modify a Layer Properties Filter definition with VLISP?" ??
That seems to me to be a more sensible approach. What do you think?
You are right. The phrasing of the question is due to my poor English.
Meanwhile, I found a detour to the filter problem.
Apparently, if you issue the layer command, and although not appearing in the layer prompt, you can answer "filter" and be able to manipulate (create, delete and edit) the layer filter. You can not (unfortunately) obtain the filters names.
Eitan
