Add partref / part reference using VB-code (entmake)
0 REPLIES 0
Message 1 of 1
317 Views, 0 Replies
I want to create a "Part Reference" by using code.
Previously I have used the "command input" for simply generating drawings. For example crating an arc
(command "arc" "c""-642.2,4400.2""-605,4400.2""a""-128")
My hope was that I could use the same method when creating a part reference ("partref") eg.
(command "ampartref" "500,500")
But after "500,500" a window appear (Part reference component properties) which I don't know how to control through the code. (see attached file)
Is there a way to edit/ add text in this window by using VB-code?
Is it possible to use entmake? In that case how can this be done?
Help would be appreciated!
//ponjoh
0 REPLIES 0
”Boost
