Visual LISP, AutoLISP and General Customization
Active Member
joeyl10
Message 1 of 2 (435 Views)
add numbers lisp
435 Views, 1 Replies
10-15-2008 03:46 PM
i can't seem to get this lisp to add numbers unless they have a whole number in front of them as in 0 3/4", 1'-2 1/4... it will not add 3/4", 1/4"..., it reads the number as 3 or 1 respectively. can someone see what i'm missing?
(DeFun FixStr(Str)
(While (Member (SubStr Str 1 1)
'("0" "1" "2" "3" "4" "5" "6" "7" "8" "9"))
(SetQ Str (SubStr Str 2))))
(DeFun C:Add()
(SetQ Fun + Pmpt "\nAdding machine: pick screen +num >() " Tot 0.0)
(While (Not (Null Fun))
(While (SetQ E
(EntSel (StrCat (SubStr Pmpt 1 20) (RToS Tot) (SubStr Pmpt 21) )))
(SetQ Str (Cdr (Assoc 1 (entget(car e))))
Tot (Fun Tot
(ProgN
(SetQ Num (Float (AToI Str)))
(SetQ Str (FixStr Str))
(If (= (SubStr Str 1 2) "'-")
(ProgN (SetQ Num (* Num 12.0) Str (SubStr Str 3))
(SetQ Num (+ Num (Float (AToI Str))))
(SetQ Str (FixStr Str))))
(If (/= (SetQ F (Float (AToI Str))) 0)
(+ (/ F (AToI (SubStr (FixStr (SubStr Str 2)) 2))) Num)
Num))))
); end while get input
(SetQ F T)
(While F
(SetQ St (GetString "\nOptions +, -, k, q : "))
(Cond
((Member St '("q" "Q" ""))
(SetQ F Nil Fun Nil))
((= St "+")
(SetQ Fun + Pmpt "\npick screen +num >() " F Nil))
((= St "-")
(SetQ Fun - Pmpt "\npick screen -num >() " F Nil))
((Member St '("k" "K"))
(While (/= "" (SetQ Str
(GetString (StrCat "\nEnter keyboard num (" (RToS Tot) ") : "))))
(SetQ Num (AToF Str)
Sign (If (MinusP Num) -1 1)
Num (* Num Sign)
Ft (Fix Num)
Num (* (- Num Ft) 100.0)
In (Fix (+ Num 1.0e-12))
Num (- Num In))
(If (< Num 1.0e-12) (SetQ Num 0.0))
(SetQ Num (+ (* Ft 12.0) In (* Num 6.25))
Tot (+ Tot (* Sign Num))))))))
(SetQ StrDef (RToS Tot))
(Princ StrDef)
Edited by: joeyl10 on Oct 15, 2008 10:46 PM
*Bill Gilliss
Message 2 of 2 (435 Views)
Re: add numbers lisp
10-15-2008 10:10 PM in reply to: joeyl10
joeyl10 wrote:
i
what i'm missing?
Joey -
You're working way too hard! Try using (getdist) as below -- it will do
all the entry validation and conversion for you.
This routine accepts numbers in any format, as well as on-screen
distances. Not much error-checking, but not much needed.
-Bill
;;; AD adds a
series of numbers entered in any valid AutoCAD units
;;; format, and returns the result in current units and precision.
;;; Use of the GETDIST function provides built-in error checking
;;; and units conversion. Numbers and distances can be entered
;;; either from the keyboard or by indicating points on the screen.
;;; by Bill Gilliss. Help yourself.
(defun c:ad ( / value)
  (setq oldunits (getvar "LUNITS"))
  (setvar "LUNITS" 4)  ;accepts any input format, incl scientific
  (setq adTotal 0)
  (setq value 0)
  (princ "\nEnter a number or indicate a distance (ENTER to finish):")
  (princ "\n")
  (while (/= value nil)
   (setq value (getdist ))
   (if (/= value nil)(setq AdTotal (+ AdTotal value)));if
   (princ (strcat "\n= " (rtos AdTotal) " + "))
    );while
  (setvar "LUNITS" oldunits)
  (princ (strcat "\nAdTotal: " (rtos AdTotal )))
  (princ)
);defun
(princ "AD loaded. Result will be stored in variable AdTotal.")
(princ)
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
