Valued Mentor
mdhutchinson
Message 1 of 4 (603 Views)
Add Multiple Hyperlinks via lisp on AutoCAD objects
603 Views, 3 Replies
01-11-2013 10:02 AM
The below adds a hyperlink to the selected object.
How might it have to change to add multiple hyperlinks?
(entmod
 (append (entget (car (entsel)))
     (list
      (list -3
         (cons "PE_URL"
            (list
             (cons 1000 "..\\..\\90 Submittals\\90-3 O&Ms\\fig83-clevishanger.pdf") ; Relative Path to a pdf file.
             (cons 1002 "{")
             (cons 1000 "fig83-clevishanger.pdf"); Tooltip
             (cons 1002 "}")
Distinguished Mentor
_Tharwat
Message 2 of 4 (587 Views)
Re: Add Multiple Hyperlinks via lisp on AutoCAD objects
01-11-2013 12:34 PM in reply to: mdhutchinson
Maybe this .....
(if (setq ss (ssget "_:L"))
  (repeat (setq i (sslength ss))
    (setq sn (ssname ss (setq i (1- i))))
    (entmod
      (append
        (entget sn)
        (list
          (list
            -3
            (cons
              "PE_URL"
              (list
                (cons
                  1000
                (cons 1002 "{")
                (cons 1000 "fig83-clevishanger.pdf") ; Tooltip
                (cons 1002 "}")
  (princ)
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Valued Mentor
mdhutchinson
Message 3 of 4 (584 Views)
01-11-2013 12:38 PM in reply to: _Tharwat
oops... I didn't make myself clear.
What I was hoping for was to attach multiple hyperlinks to the same object... such that when you right click on the object you would see multiple hyperlinks with each link going to a different object (pdf file, word doc, excel file, etc).
pbejse
Message 4 of 4 (561 Views)
01-12-2013 08:43 AM in reply to: mdhutchinson
To date, i only worked on hyperlink with lisp code just once  and i'm not even sure you can assign mulitple HPlinks on a single object. thats why in the past i suggested to use a block and run a routine similar  to this :
(defun c:goto ( / tmp hp filetype URL)
 (cond ((and
          (setq tmp (vlax-ename->vla-object (Car (nentsel))))
 	  (> (vla-get-count (setq hp (vla-get-hyperlinks tmp ))) 0)
	  (setq filetype (last (fnsplitl (setq URL (vla-get-URL  (vla-item hp 0))))))
          (setq appfor (assoc filetype
                              '((".LSP" "NOTEPAD");| other file type and their apps"|;)))
      	  (startapp (cadr appfor) URL))
It wont be like a the usual Hyperlink wherein you do a mouse-over to know which objects has a HP. but it works nonetheless
So i guess , with the same line of reasoning you can assign multiple HP on an object granting its a block
HTH
