I am having a hard time with figuring out how to add characters to the end of a string.
Each line must have a separate label based on the original line numbering. (example 1-1, 1-120, 50-120, 100-100, etc).
They lines are always 2 numbers separated by a "-".
When I have an attached subline, I need to add an "a" to the to get 1-1a. I thought I could get away with only 26 characters 1-1, 1-1a to 1-1z, but I now need to have an unlimited number.
Once I reach the "z" subline, I need to start over with "aa".
Examples -
1-1
1-1a
1-1b
1-1z
next line will be -
1-1aa
1-1ab
1-1az
next line will be -
1-1aaa
1-1aab
and so forth
What I need is a subroutine to check a Variable and add 1 letter
Here is what I have to start with line without a letter, then add character or increment.
(defun Test ()
(if (= 122 (ascii (substr Current_Wire (strlen Current_Wire))))
(progn
(alert (strcat "\nERROR - Current Wire " Current_Wire " is at maximum letter."))
(exit)
(if (wcmatch Current_Wire "*#")
(setq Current_Wire (strcat Current_Wire "a"))
(setq Current_Wire (strcat (substr Current_Wire 1 (1- (strlen Current_Wire))) (chr (1+ (ascii (substr Current_Wire (strlen Current_Wire)))))))
Current_Wire
Thanks in advance!!!
Solved by mracad. Go to Solution.
This should do what you want, if I'm reading the post right. If it doesn't, then it should give you a good head start.
{code}
(defun UpRevisionString (String / tmpPos tmpStr tmpStr2 tmpStr3 EndStr tmpAddValue)
; Update to the new revision. A->B, Z->AA, AZ->BA, AZA->AZB
(setq tmpPos (strlen String))
(while (and (/= tmpPos 0) (= (setq tmpStr (substr String tmpPos 1)) "Z"))
(setq tmpPos (1- tmpPos))
(if tmpStr2
(setq tmpStr2 (strcat "A" tmpStr2))
(setq tmpStr2 "A")
(if (= tmpPos 0)
(repeat (1+ (strlen String))
(if EndStr
(setq EndStr (strcat EndStr "A"))
(setq EndStr "A")
(progn
(setq tmpStr3 (substr String 1 (1- tmpPOs)))
(if (or (= tmpStr "H") (= tmpStr "N") (= tmpStr "P"))
(setq tmpAddValue 2)
(setq tmpAddValue 1)
(setq tmpStr (chr (+ tmpAddValue (ascii tmpStr))))
(cond
(EndStr
EndStr
((and tmpStr tmpStr2 tmpStr3)
(strcat tmpStr3 tmpStr tmpStr2)
((and tmpStr tmpStr3)
(strcat tmpStr3 tmpStr)
{code}
Examples:
Command: (uprevisionstring "A")
"B"
Command: (uprevisionstring "Z")
"AA"
Command: (uprevisionstring "ZA")
"ZB"
Command: (uprevisionstring "ZZ")
"AAA"
Forgot to mention that it will skip ' I, O, Q ' letters, as those can't be used for drawing revisions here, but that is an easy change.
thanks....after reviewing your routine I had an epiphany...here is the updated code -
(defun Circuit_Number_Next ()
(cond
;--current wire ends with a number-------------------
((wcmatch Current_Wire "*#")
;--current wire ends with "z"------------------------
((= 122 (ascii (substr Current_Wire (strlen Current_Wire))))
(setq Current_Wire (strcat (substr Current_Wire 1 (1- (strlen Current_Wire))) "aa"))
;--increment last letter-----------------------------
(T
You might want to try that code with a number that ends in a ' zz ' and see what happens. That case may not be likely to happen, but I would rather code to make sure that if it happens, then the returned value is correct.
I'm around Buddy, but only post when something hasn't been answered, or I can show another way to skin a cat, as there are a lot of smart people here helping nowadays. Thanks for the warm welcoming, as it put a smile on my face. Have a good one Buddy!
@mracad wrote:I am having a hard time with figuring out how to add characters to the end of a string.
Examples -
1-1
1-1a
1-1b
1-1z
next line will be -
1-1aa
1-1ab
1-1az
next line will be -
1-1aaa
1-1aab
Shouldn't that be
1-1az
1-1ba
1-1bb
1-1bz
1-1ca
1-1cb
1-1zz
1-1aaa
etc.
