ActiveX Server Error in 2013 and 2014 VLA-ADD
3 REPLIES 3
donbutler
1022 Views, 3 Replies
The following snippet works in 2012 but fails in 2013 and 2014
(if layer
        (progn
             (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
                (if (vl-catch-all-error-p
                      (setq objlay (vl-catch-all-apply 'vla-item (list lays layer)))
                  (setq objlay (vla-add lays layer))
        (setq objlay (vla-get-activelayer (vla-get-activedocument (vlax-get-acad-object))))
This line ...
Returns:
error: ActiveX Server returned an error: Library not registered
Anyone have an idea what's wrong?
3 REPLIES 3
donbutler
in reply to: donbutler
It looks like the error is coming up in other locations too. I'll keep digging.
Works for me in 2013 sp1:
Comando: (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
#<VLA-OBJECT IAcadLayers 0000000028533888>
Comando: (setq objlay (vla-add lays "NEWLAYER"))
#<VLA-OBJECT IAcadLayer 0000000028534de8>
Marc'Antonio Alessi
http://alessi.xoom.it//alessi/Programmi.htm
(vl-string-translate "1234567890" "ie@mst.lan" "499825513610716")
2D Parametric for 2000-2013
chicodon
Thanks. I had uninstalled AutoDesk 360 and something happened. I reinstalled AutoCad 2014 and now everything is working. Thanks for your input.
Don Butler
”Boost
