Has anyone tried retrieving an ActiveX selection set in AutoCAD 2013 (AutoCAD Architecture 64bit on Windows 7 is what I am using)?
Using a piece of LISP I got from the ADN developer site, it no longer works and gives this error....
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
(defun c:erset (/ acApp acDoc selSets ss1)
(vl-load-com)
(setq acApp (vlax-get-acad-object))
(setq acDoc (vla-get-activeDocument acApp))
(setq selSets (vla-get-SelectionSets acDoc))
(setq ss1 (vla-item selSets "TEST1"))
(princ "Number of items in selection set TEST1 = ")
(princ (vla-get-count ss1))
(if (> (vla-get-count ss1) 0)
(progn
(alert "Erasing objects in selection set TEST1")
(vla-erase ss1)
) ;progn
) ;if
(princ)
) ;defun
Same with a similar one I found via google and have been using it for years. Unfortunatley my lisp is very basic so I have little idea if it an be fixed!
(defun c:getSset()
(vl-load-com)
(setq ss-vba (vla-item
(vla-get-selectionsets
(vla-get-activedocument
(vlax-get-acad-object)))
"SSforLisp"));; gets the ActiveX SS
(setq ss-lisp (ssadd));;creates a new ename-based ss
(vlax-for ent ss-vba
(ssadd (vlax-vla-object->ename ent) ss-lisp)
);;add each object's ename to the ename-ss
What about creating an AutoLisp selection set from .NET - is it possible, if so I would prefer to do that instead?
The goal is to create some objects in .NET (using activeX or managed code) and then have some way to access these objects via the command line I'm assuming they only way is using an AutoLISP selection set.
Many thanks,
Graham
MiTek Industries
Solved by Hallex. Go to Solution.
UPDATE...
I found a sample to transfer a selection set into lisp (using a VB.NET lisp function). Not tested it out yet but it looks promising, I think I need to transfer my activex objects into managed ones and then build a selection set and result buffer?
<LispFunction("MyLispFunction2")> _
Public Function VBNetFunction4(ByVal myLispArgs As ResultBuffer) As ResultBuffer
Dim rbfResult As ResultBuffer
Dim ed As Autodesk.AutoCAD.EditorInput.Editor
ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim prmptSelOpts As New PromptSelectionOptions()
Dim prmptSelRes As PromptSelectionResult
prmptSelRes = ed.GetSelection(prmptSelOpts)
If prmptSelRes.Status <> PromptStatus.OK Then
rbfResult = New ResultBuffer(New TypedValue(5019))
Return rbfResult
End If
Dim selSet As SelectionSet
selSet = prmptSelRes.Value
rbfResult = New ResultBuffer( _
New TypedValue(CInt(5007), selSet))
Return rbfResult
End Function
Worked on my end with small changes:
<LispFunction("MyLispFunction2")> _ Public Function VBNetFunction4(ByVal myLispArgs As ResultBuffer) As ResultBuffer Dim rbfResult As ResultBuffer Dim ed As Autodesk.AutoCAD.EditorInput.Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor Dim prmptSelOpts As New PromptSelectionOptions() prmptSelOpts.MessageForRemoval = vbLf + "Nothing selected" prmptSelOpts.MessageForAdding = vbLf + "Select some objects:" Dim prmptSelRes As PromptSelectionResult prmptSelRes = ed.GetSelection(prmptSelOpts) If prmptSelRes.Status <> PromptStatus.OK Then rbfResult = New ResultBuffer(New TypedValue(5019)) Return rbfResult End If Dim selSet As SelectionSet selSet = prmptSelRes.Value ed.SetImpliedSelection(selSet) rbfResult = New ResultBuffer( _ New TypedValue(CInt(5007), ed.SelectImplied.Value)) Return rbfResult End Function
In the command line I've typed
(setq sset (MyLispFunction2))
Another way with using pickfirstselectionset,
see what this function will retain for you:
' (selected objects) <LispFunction("ListSelected")> _ Public Shared Function ListSelected(resBufIn As ResultBuffer) As ResultBuffer Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim blkId As ObjectId = db.BlockTableId Dim resBufOut As New ResultBuffer() If ed.SelectImplied.Value.Count = 0 Then ed.WriteMessage(vbLf + "Works with previously selected objects only!") resBufOut.Add(New TypedValue(CInt(LispDataType.Nil))) Else Using tr As Transaction = db.TransactionManager.StartOpenCloseTransaction() Dim bt As BlockTable = TryCast(tr.GetObject(blkId, OpenMode.ForRead), BlockTable) resBufOut.Add(New TypedValue(CInt(LispDataType.ListBegin))) Dim sset As SelectionSet = ed.SelectImplied.Value For Each sobj As SelectedObject In sset resBufOut.Add(New TypedValue(CInt(LispDataType.ObjectId), sobj.ObjectId)) Next resBufOut.Add(New TypedValue(CInt(LispDataType.ListEnd))) End Using End If Return resBufOut End Function '' usage : (setq entlist (ListSelected))
Glad to hear that,
Kind regards,
Cheers 🙂
