Setting acadlspasdoc tells AutoCAD to reload Acad.lsp for each document
opened (which is what acaddoc.lsp is for).
Gary,
I'm trying to understand your post.
Are you saying that setting the acadlspasdoc variable causes AutoCAD to reload Acad.lsp for each document no matter if it's set to 0 or 1?
The help files says:
0 Loads acad.lsp into just the first drawing opened in an AutoCAD session.
1 Loads acad.lsp into every drawing opened .
Bill
>> > Setting acadlspasdoc tells AutoCAD to reload Acad.lsp for each document > opened (which is what acaddoc.lsp is for). > <<>> > Gary, > I'm trying to understand your post. > Are you saying that setting the acadlspasdoc variable causes AutoCAD to reload Acad.lsp for each document no matter if it's set to 0 or 1? > > The help files says: > > 0 Loads acad.lsp into just the first drawing opened in an AutoCAD session. > > 1 Loads acad.lsp into every drawing opened . > > > Bill
