Visual LISP, AutoLISP and General Customization
New Member
ashfaqhadi
Message 1 of 6 (10,349 Views)
acaddoc.lsp virus
10349 Views, 5 Replies
06-04-2011 07:54 AM
I Have problem when i open autocad 2008 & 2011
the below message appears in the command line.
and when ever i open the drawing from the folder there is automatically a file created in the folder named acaddoc.lsp
can any one help me to remove this threat from the autocad software
i have also re-installed the autocad software but the same problem is repeated again
"AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.; error: LOAD failed: "acadapq"
Command: COMMANDLINE
Command: properties"
Edited by
Discussion_Admin
diagodose2009
Message 2 of 6 (10,340 Views)
Re: acaddoc.lsp virus
06-04-2011 02:25 PM in reply to: ashfaqhadi
see my image yes is a virus
Active Contributor
ehya
Message 3 of 6 (10,266 Views)
06-06-2011 07:28 AM in reply to: ashfaqhadi
To delete the virus,Dwg file is located in the folder, delete files in the LSP.Install the following file.
The command line to run the program "AcdDcCLr" type .
DWG file before starting another, if there are files in the folder, delete them LSP.
Active Contributor
zingero84
Message 4 of 6 (7,559 Views)
05-03-2012 03:48 AM in reply to: ashfaqhadi
Does this fix actually work?
I am having the same problem and it's VERY ANNOYING.  I have no clue how i got this virus because I don't even have time to do anything else at work but work.
All of my drawing file folders have the acaddoc.lsp in them.  If I delete it before opening, they is no virus wanring.  If I leave it there and open it, I get a virus warning.
How do I permanently remove this virus from my computer?
Active Contributor
zingero84
Message 5 of 6 (7,554 Views)
05-03-2012 03:51 AM in reply to: ashfaqhadi
Here is my opening command line info:
Opening an AutoCAD 2004/LT 2004 format file.
Substituting [Arial00000034] for [Myriad Apple].
Resolve Xref "12-013 22x34": X:\12-013 22x34.dwg
"12-013 22x34" loaded.
Resolve Xref "OH ELECT": X:smileysurprised:H ELECT.dwg
"OH ELECT" loaded.
Resolve Xref "12-013 bldg type a": X:\12-013 bldg type a.dwg
"12-013 bldg type a" loaded.
Resolve Xref "12-013 bldg type b": X:\12-013 bldg type b.dwg
"12-013 bldg type b" loaded.
Regenerating layout.
Regenerating model.
C:NEWDATEno function definition: ACET-AUTOLOAD2
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command:
Active Contributor
zingero84
Message 6 of 6 (7,067 Views)
05-23-2012 12:08 PM in reply to: zingero84
I cannot get rid of this virus.
Can someone help me out?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
