We just loaded LT 2011 (formerly used AutoCAD 2006) and some of the commands I'm used to using are gone. I can't seem to find an acad.pgp file so that I can change "c" from 'copy' to 'circle'.
If there is no .pgp file available, how do I go about updating the keyboard shortcuts for various commands?
Deanna
Firstly have you installed the ExpressTools. It's an extra tick (don't go default).
In ET there is a command called AliasEdit that will open the Acad.pgp file and give you an interface.
What operating system are you using?
on my XP it's in here
C:\Documents and Settings\USERNAME\Application Data\Autodesk\ACA 2011\enu\Support
No, I did not install the Express tools. I was told to just go with the default installation. That should never be my choice as I like to personalize all of my commands. I am going to update my install with the Express tools and then I'll let you know how it worked out. Thanks for the info!
Deanna
I meant the acad.pgp is here
