acad.pgp for AutoCAD LT 2011?
5 REPLIES 5
5872 Views, 5 Replies
We just loaded LT 2011 (formerly used AutoCAD 2006) and some of the commands I'm used to using are gone. I can't seem to find an acad.pgp file so that I can change "c" from 'copy' to 'circle'.
If there is no .pgp file available, how do I go about updating the keyboard shortcuts for various commands?
Deanna
5 REPLIES 5
ntellery
Firstly have you installed the ExpressTools.  It's an extra tick (don't go default).
In ET there is a command called AliasEdit that will open the Acad.pgp file and give you an interface.
What operating system are you using?
on my XP it's in here
C:\Documents and Settings\USERNAME\Application Data\Autodesk\ACA 2011\enu\Support
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
in reply to: ntellery
No, I did not install the Express tools. I was told to just go with the default installation. That should never be my choice as I like to personalize all of my commands. I am going to update my install with the Express tools and then I'll let you know how it worked out. Thanks for the info!
Deanna
ntellery
I meant the acad.pgp is here
Thanks! Updating my .pgp file worked. Glad to have my old commands available at my fingertips!
Deanna
abouzane
you rock.
needed that user subfolder in the **** support file seach path.
lame.
”Boost
