the lisp problem is likely a mismatched bracket, quote etc.
Must be before your hotkey definitions?
cheers
Steve
tevans1 wrote in message
news:f09079e.-1@WebX.maYIadrTaRb...
| I am having dificulties with converting both of these files to run with
ADT 3.3.
| First when I load our acad.lsp I get an error that reads:
| ; error: malformed list on input
| then none of the hot keys work such as:
| (defun c:ze () (command "zoom" "e" ))
| which should do a zoom extents but I get an unkown command error.
| The other problem is with our custom menu. When the pull-down selection
calls another menu it appears in the acad.mnu pop location such as
| a.. **POP2
| b.. *ENGR Id_engr [&Eng Main]
| [BasePlan]$P2=RS2K2.ENGE0 $P2=RS2K2.*
| [E1 Sheet]$P2=RS2K2.ENGE1 $P2=RS2K2.*
| these would show up in the Pop2 location and replace that menu (edit)
| any suggestions?
