Visual LISP, AutoLISP and General Customization
acad.lsp and *.mnu
1 REPLY 1
ted.evans
133 Views, 1 Reply
acad.lsp and *.mnu
I am having dificulties with converting both of these files to run with ADT 3.3.
First when I load our acad.lsp I get an error that reads:
; error: malformed list on input
then none of the hot keys work such as:
(defun c:ze () (command "zoom" "e" ))
which should do a zoom extents but I get an unkown command error.
The other problem is with our custom menu. When the pull-down selection calls another menu it appears in the acad.mnu pop location such as
***POP2
**ENGR
Id_engr [&Eng Main]
[BasePlan]$P2=RS2K2.ENGE0 $P2=RS2K2.*
[E1 Sheet]$P2=RS2K2.ENGE1 $P2=RS2K2.*
these would show up in the Pop2 location and replace that menu (edit)
any suggestions?
1 REPLY 1
in reply to: ted.evans
the lisp problem is likely a mismatched bracket, quote etc.
Must be before your hotkey definitions?
cheers
Steve
tevans1 wrote in message
news:f09079e.-1@WebX.maYIadrTaRb...
ADT 3.3.
| a.. **POP2
| b.. *ENGR Id_engr [&Eng Main]
| any suggestions?
”Boost
