My two cents:
I'm afraid that for such ambitious task, grread is too primitive a tool.
Most probably it will take something like .NET and some Windows API
function(s) in order to control the mouse the way you want it.
Regards
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
a écrit dans le message de news:
6271274@discussion.autodesk.com...
Using Autolisp I want to write code which differentiates between the
still and moving state of mouse. I have written a number of test codes to
do the task. One of them is given below, I have used the grread function.
So far I am not able to achieve the goal. In the following program I have
tried to display state of mouse on command line, i.e. if it is moving or
still.
But even if I continueusly move the mouse the output of the program is like
this
mouse is moving
mouse is still
mouse is moving
mouse is still
Which I do not understand why, if the mouse is continueusly moving the
program
should only display mouse is moving and not the other message. Please guide.
(defun c:tst()
(setq coor nil) ; To store coordinates returned by grread.
(setq code nil) ; To store the integer code returned by grread.
(while(/= code 3)
(setq input(grread t))
(setq code(car input))
; If input is being read for first time.
(if(= nil coor)
(progn
(setq coor(cadr input))
(progn
(setq newCoor(cadr input))
(if(equal newCoor coor)
(progn
(princ "mouse is still\n")
(progn
(princ "mouse is moving\n")
(setq coor newCoor)
Secondly, according to help of grread we can pass a number of arguments. I
want to use grread such that it works only
when I move the mouse or If I press a keyboard key. is it possible to do
that if so what arguments values we need to pass it.
I think if we use (grread T) it returns the cursor coordinates with return
code 5 even if we do not move mouse.
