Visual LISP, AutoLISP and General Customization
Abort insert with command-s
5 REPLIES 5
pierre.lassard
427 Views, 5 Replies
With AutoCAD 2014, i often use a lisp like :
(mapcar '(lambda (x)
(progn
   (Command "Insert" x)
   (Command)
'("C:\\Temp\\Testblock.dwg" "C:\\Temp\\Testblock2.dwg" ...)
The block is loaded in the DWG but i don't want to insert this block immediatly. For example, just to redefine the block.
With AutoCAD 2015, this lisp create an error,i know it' s not possible to use Command or vl-cmdf with Mapcar.
But i can't use (command-s).
Is there a way to load blocks without inserting with Autolisp or Visual Lisp.
Thanks !
5 REPLIES 5
@pierre.lassard wrote:
....With AutoCAD 2014, i often use a lisp like :
(progn
Does it need to be via (mapcar)?  Try it, for example, this way [I'm not where I have 2015 right now to test it]:
(foreach x '("C:\\Temp\\Testblock" "C:\\Temp\\Testblock2" ...)
  (command "_.insert" x) (command)
[By the way, you don't need to include the .dwg filetype ending -- it won't recognize any other filetype to Insert.]
Kent Cooper, AIA
I Know it's possible to use foreach or repeat.
But my lisp function is more complex and i want to Return list value, then i d prefer use mapcar.
hgasty1001
in reply to: pierre.lassard
You can insert a block using entmake/entmakex as this a pure autolisp function you can use it inside a mapcar.
Gaston Nunez
Lee_Mac
Try the following method:
(vl-load-com)
(setq spc (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(mapcar
   '(lambda ( dwg )
        (if (findfile dwg)
            (progn
                (vla-delete (vla-insertblock spc (vlax-3D-point 0 0) dwg 1.0 1.0 1.0 0.0))
                dwg
   '("C:\\Temp\\Testblock.dwg" "C:\\Temp\\Testblock2.dwg")
By supplying the ActiveX insertblock method with a full filepath, the block should be redefined if already present in the Block Collection of the active drawing. The above example will return a list of the filepaths of those blocks successfully defined/redefined.
pierre.lassard
in reply to: Lee_Mac
Of course.
This is the best Idea.
Insert block, and delete it.
”Boost
