Visual LISP, AutoLISP and General Customization
3D CYLINDER LISP
19 REPLIES 19
Message 1 of 20
2142 Views, 19 Replies
3D CYLINDER LISP
Hoping someone could point out a lisp that will draw a 3d solid cylinder
based on selecting endpoints and specifying a diameter. Of course it has to
be able to do it regardless of ucs settings. Anybody know where to find one?
PS. tried www.cadalog.com already, no luck.
Thx.
19 REPLIES 19
Message 2 of 20
Try 1)www.autosolids.com 2)do it without lisp by drawing a
circle, extrude the circle and use vpoint to whatever ucs
you want and 3)wait till someone post or send you the lisp.
Message 3 of 20
What's wrong with the CYLINDER command? ...or just drawing a circle and
EXTRUDEing it?
___
"The real JD" wrote in message
news:A3F53D567651B54C49B54C453451B3C7@in.WebX.maYIadrTaRb...
to
one?
Message 4 of 20
Gee Paul, beat me to it. CYLINDER->(pick center)->(enter radius)->C (for center other end)->(pick enter other end). Of course you can write a script or lisp to add the "C" I guess.
Message 5 of 20
I just want it to work regardless of ucs. I know
about the Cylinder command. But when you use it, it extrudes based on your
current ucs. then i have to rotate or align the cylinder to have it match
up.
So...
Looking for
pick endpoint of cylinder
pick other enpoint
specify dia.
that's it.
Try to do a cylinder by picking two points with the
z value of zero, you'll see what i mean.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Gee
Message 6 of 20
What version of ACAD are you using? In R14+ the CYLINDER command will create cylinders in any direction regardless of UCS orientation. Read the prompts, after entering the radius it asks "Specify height of cylinder or [Center of other end]:" Enter a C (for Center other end) then pick something.
Message 7 of 20
Using A2ki. Seems to extrude based on my current
UCS. Maybe there's a system variable for this?
Have you tried creating a cylinder
with:
UCS world,
and picking to points with the same z and have it
work. If so, it's not working for me. it always creates the cylinder extruded,
based on UCS.
Really, i tried picking center for both endpoints,
but it doesn't work right. I have to rotate the cylinder and align it to the
points i originally selected.
Thx for the feedback.
What
something.
Message 8 of 20
Well ... if you insist:
(defun C:CYL (/ p1 p2 dia)
(setq p1 (getpoint "\nStarting point: ")
p2 (getpoint "\nEnding point: ")
dia (getdist "\nDiameter: "))
(command "_.cylinder" p1 (/ dia 2.0) "_c" p2)
(princ)
___
news:E1A9F924DF7061B63E56E27ADF757116@in.WebX.maYIadrTaRb...
Message 9 of 20
Key-in CYLINDER, it prompts "Specify center point for base of cylinder or [Elliptical] <0,0,0>:" you pick a point, any point. It prompts "Specify radius for base of cylinder or [Diameter]:" key-in a radius. It prompts "Specify height of cylinder or [Center of other end]:" See the "CENTER OF OTHER END" part? ENTER a C, then pick a point on the other side of the drawing. What do you get?
Message 10 of 20
Thanks Paul, sometimes ir's just easier, eh?
Message 11 of 20
Sure ... why do it the easy way, when you can complicate it with a little
LISP? 8-))
___
"OLD-CADaver" wrote in message
news:f15906e.8@WebX.maYIadrTaRb...
Message 12 of 20
Very nice lispy Paul,
I learn something new today 😉
from an old cad but not -aver...
"Paul Turvill" wrote in message
news:0AD02A8FF6B032D01833C748FCC3EC36@in.WebX.maYIadrTaRb...
> LISP? 8-))
> ___
Message 13 of 20
snicker
Message 14 of 20
This is the result of 3 hours of sleep a night for the past 3 nights.
I kept forgeting the bloody "c" for other centerpoint.
So I'm glad, i could provide some fun for all of you.
Paul, thanks for the lisp. I've changed it a bit:
(defun C:Duh (/ p1 p2 dia)
(prompt "\nThis will draw a cylinder for those who can't read the command
line!!")
(princ)
> LISP? 8-))
> ___
Message 15 of 20
Can you translate that word into plain English or Spanish, please?
snicker
Message 16 of 20
A slightly stifled, sarcastic laugh. Sorry, can't help with the Spanish.
Message 17 of 20
Go home, take a nap, tomorrow comes anyway. 😉
Message 18 of 20
shanesparks
Could write you one for a small fee.
Shane
ssparks@northlandenergy.com
Message 19 of 20
Paul provided a free one about ten posts up.
Message 20 of 20
Dorecore
Is it possible to make a lisp command that find two points of the same X & Y coordinates and creates a cylinder between them given a certain radius? I have several hundred cylinders to create and thought there would be a way to streamline the process.
”Boost
