My company wants to do the following:
1) open a subdirectory
2) open each drawing in that subdirectory
3) 2DREP the drawing
4) detach the XREF's
5) save the drawing
6) close the drawing
7) open the next drawing in the subdirectory
😎 repeat steps 1-7 until all drawings have been processed
I can muddle through writing a lisp routine to do this but have no idea how to make it complete each drawing in the subdirectory. I can write a routine but theuser must open each drawing manually.
Any help would be appreciated.
i have some lisp files for modifying many drawings like plotting, change title-block, etc.
Here is a template for you:
;globale Variablen
; INT: int_lispinit altueller Wert von 'lispinit'
; STRING: str_pfad Pfad fuer DWG-Verzeichniss
; LIST: list_dwg Liste mit allen DWG-Zeichnungsnamen ohne Pfad
;Funktion
(defun c:functionname ( / int_lispinit str_pfad list_dwg)
(vl-load-com)
;----- aktuelle Systemvariablenwerte sichern
;----- save system variables
(setq old_lispinit (getvar "lispinit"))
;----- Systemvariablen veraendern
;----- modify ACAD variables
(setvar "cmdecho" 0) ;Command echo: aus
(setvar "lispinit" 0) ;LISP-Prg. Speicherresistent
(setvar "sdi" 1) ;Single Document Interface
;----- Abfrage: Verzeichnis mit getfiled
;----- Userinput: select directory with getfiled
(setq str_pfad (gfm-getFolder "Ordner mit allen Zeichnungen zum Bearbeiten:" ""))
;----- Liste mit allen Zeichnungsnamen im Verzeichnis bilden
;----- create list with all drawings into directory
(setq list_dwg (vl-directory-files str_pfad "*.dwg" 1))
;----- Schleife: Jede Zeichnung öffnen und bearbeiten
;----- loop: open each drawing and modify it
(foreach str_Zeichnung list_dwg
;----- Zeichnung öffnen
;----- open dwg
(if (> (getvar "DBMOD") 0)
(command "_.open" "_y" (strcat str_pfad "\\" str_Zeichnung))
(command "_.open" (strcat str_pfad "\\" str_Zeichnung))
);endif
;----- Zeichnung bearbeiten
;----- modify drawing
(<your-function>)
;----- Zeichnung speichern
;----- save drawing
(command "_.qsave")
);end foreach
;----- Systemvariablen-Werte wiederherstellen
;----- restore variables
(setvar "sdi" 0)
(setvar "lispinit" old_lispinit)
(setvar "cmdecho" 1)
(princ)
);enddefun
;Titel: GFM-GETFOLDER fuer ACAD2000-2008
;Erklaerung: Funktion öffnet den Windowsdialog zum Auswählen eines Verzeichnisses
;Datum: Feb. 2009
;Autor: Ing. Franz Kefer
;lokale VARIABLEN
;VLA-Objekt: objShell Shell Objekt
; folder Ordner
; objFolder Ordner Objekt
; STRING: str_Path Ausgewählter Ordner(pfad)
; AUFRUF: (gfm-getFolder str_Kommentar str_rootDir)
; Argumente: str_Kommentar Kommentar im Windows Ordnerdialogfeld
; str_rootDir Vorgabeverzeichnis oder Laufwerk für Ordnerauswahl
(defun gfm-getFolder (str_Kommentar str_rootDir / objShell folder objFolder str_Path)
;----- Vorbild aus VB
;set ShellApp=CreateObject("Shell.Application") 'erzeuge ein neues Objekt "Shell Application"
;set FolBrowser=ShellApp.BrowseForFolder(0,"Wähle einen Ordner",16,0) '16 = zusätzl. Ordnerfeld wird angezeigt
;----- VL-Extension laden
(vl-load-com)
;----- Shell Objekt
(if (setq obj_Shell (vla-getinterfaceobject (vlax-get-acad-object) "shell.application"))
(progn
;----- Ordner Objekt bestimmen
(setq folder (vlax-invoke-method obj_Shell 'browseforfolder 0 str_Kommentar 0 str_rootDir))
;----- Shell Objekt beenden
(vlax-release-object obj_Shell)
;----- Ordnerpfad auslesen
(if folder
(progn
(setq obj_Folder (vlax-get-property folder 'self))
(setq str_Path (vlax-get-property obj_Folder 'path))
(vlax-release-object obj_Folder)
(vlax-release-object folder)
);end progn
;ELSE
(quit)
);end if
);endprogn
);endif
;----- Rückgabewert
str_Path
);enddefun
kind regards,
Franz
