VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
work on autocad from MATLAB
6 REPLIES 6
3685 Views, 6 Replies
Is it possible to run autocad and perform VBA-like commands from Matlab.
If yes please give me some references or any info for a 'jump start'
Thanks you
Tuli
6 REPLIES 6
Tuli,
www.mathworks.com
Go there and do a search for AutoCAD, I believe you might find what your looking for.
G'Luck
Bob
feature('COM_SafeArraySingleDim', 1);feature('COM_PassSafeArrayByRef', 1);
AcadApp=actxserver('AutoCAD.Application.19.1'); % AutoCAD2014
AcadApp.Visible = true();
AcadDoc = AcadApp.ActiveDocument;
AcadModelSpace = AcadDoc.ModelSpace;
lineObj = AcadModelSpace.AddLine([0,0,0]',[1,0,0]'); % drawing a line
% i am just starting it, all the codes above are available. But there are problems when i tried to AddRegion.
% if you know how to AddRegion, i'll be very grateful!Heart
caplazy
Very thanks for your share! The 'feature' is unbelievable.
This question has been bothering me for many days, now it has been solved, I feel very happy.
And, I really hope we can have more communication, looking forward to your replay.
rabail.khan
Hi, when i use the handles for outer and inner boundary of hatch in autocad i get the following error:
Error using Interface.240A7B13_918B_4CDC_B1E5_A5ED42867FD0/AppendInnerLoop
Invoke Error, Dispatch Exception:
Source: AutoCAD.Application
Description: Invalid object array
Help File: C:\Program Files\Autodesk\AutoCAD 2020\HELP\OLE_ERR.CHM
Help Context ID: 8021007b
Here is my code:
acad = actxGetRunningServer('AutoCAD.Application');
documents = acad.Documents;
e_doc=documents.Open('D:\matlab\UKPNgrp.dxf');
acad.Visible = true();
AcadModelSpace = e_doc.ModelSpace
archandle = AcadModelSpace.AddArc([5;3;0], 3, 0, 3.142)
hatchHandle = AcadModelSpace.AddHatch(0, "ANSI31", 0)
lineHandle = AcadModelSpace.AddLine (archandle.startPoint', archandle.endPoint') %take transpose so coordinates are column matrix
circleHandle = AcadModelSpace.AddCircle([5; 4.5; 0], 1)
hatchHandle.AppendOuterLoop ([archandle; lineHandle])
hatchHandle.AppendInnerLoop (circleHandle)
orellandres
in reply to: rabail.khan
Encontraste solucion?
”Boost
