OK, you want do programming with VS2005 that run inside Acad as VBA code.
There are two ways for you to choose.
1. With VS2005 (VB.NET or C#), you can only do program that truly run inside
Acad using ObjectARX .NET API. Inside ,NET API project, you can also use
Acad COM API by set reference to Acad Type library and Acad ObjectDBX
library. BUt the project must .NET API dll and load into AutoCAD with
command "netload".
2. You can write .NET dll and expose it as COM component and then use it in
conjunction with Acad VBA project, or stand-alone COM application.
If you want to use COM API in your VS2005 project (in must be .NET API
project, if it is to run inside Acad), the reference set to Acad type
library only gives part of COM APIs. You may also need to set reference to
"Acad/ObjectDBX common 16[17] type library", if you need more
functionalities.
Unless you want to COM DLL with VS2005, you are in wrong NG.
wrote in message news:5457129@discussion.autodesk.com...
< or you want the VB code actually
run like VBA(topic of this NG) code inside AutoCAD >
exactly
