VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
VBA tri le TXT in bloc dans listbox idem bloc écran
3 REPLIES 3
acad386
495 Views, 3 Replies
hello
in autocad block 4 line TXT
TXT1 (handle # 3)
TXT2 (handle # 2)
TXT3 (handle No. 4)
TXT4 (handle # 1)
When I recuper the string in a combobox it puts me in the order of handle
TXT4,2,1,3
I then I want in the order of the line screen TXT1,2,3,4
Thank you for your help
Bonjour
Dans le bloc autocad 4 lignes de TXT
TXT1 (handle N°3)
TXT2 (handle N°2)
TXT3 (handle N°4)
TXT4 (handle N°1)
Quand je recupere le string dans une combobox il me le met dans l'ordre du handle =>Ligne 4,2,1,3
alors que je je veux dans l'ordre de l'écran ligne 1,2,3,4
Merci pour votre aide
Public Sub LireTxt()
Dim objBloc As AcadBlock
Dim objEnt As AcadEntity
Dim objEntTxT As as AcadText
ThisDrawing.Utility.GetEntity objBlocRef, Pt1, "Sélectionnez le bloc à modifier :"
Set objBloc = ThisDrawing.Blocks(objBlocRef.Name)
    For Each objEnt In objBloc
        If objEnt.ObjectName = "AcDbText" Then
            ListBoxTxt.AddItem objEntTxT.textString
        Endif
    Next
End Sub
3 REPLIES 3
RICVBA
in reply to: acad386
you have to:
1) store LineTexts text in a temporary array
2) order the array
3) fill listbox with sorted array content
see the attached example
bye
acad386
No good code
view fichier dwg for solution
RICVBA
I got it that you wanted texts sorted by their text value
you'll find the revised code for sorting by text insertion point "Y" coordinate in
http://www.cadtutor.net/forum/showthread.php?84926-VB-Sorts-text-screen-ditto-text-block-in&p=583827...
bye
”Boost
