Hello Everyone,
I need help with the VBA code for entering block attribute values to the Attributes for Blocks in an AutoCAD Drawing.
I am new to programming.
Also I need to code for automating a P&ID drawing for which I need to do these tasks
(i) Create a new dwg file, with a specified template
(ii)The user will draw the P&ID drawing with the blocks as valves, and equipments.
(iii)The blocks have already been added with Attributes using the Attdef method.
(iv)The Block Attribute values for the blocks like pressure , temperature,medium, flow etc needs to by added by the user.
(v) The need is the add these values via a GUI preferably VBA forms .
(vi)The addition in the forms should change in the attribute definition.
Thanks a lot for your kind help.
Ashny Patrick
you used the tagging for entering search keys ... have you tried to use Google with that words: >>>click<<< ? I removed "excel" as I can't see in your question anything depending on excel ... and I added "site:forums.autodesk.com" to get only results from this forum here, but that is optional, also other sites have good answers.
So that would give you a start and then you can show us your code and your drawing (that you use as sample) to get more specific answers.
The current state is that you try to write a tool/application, we might write now code for you, but if that fits to your drawing structure, if that recognizes your type of blocks and attributes? Also if anyone writes code ... can you undestand it and modify it to fit to your needs? At least I don't think that anybody will write you a complete application here (for free), so it's really the best to show what you have up to now.
As long as we don't know where you are weqwe don't know where to pick you up.
- alfred -
Thanks a lot for your Reply.
I will learn VBA..my concern is whether VBA or VB.net is fine.
If you are open for both then I would not spend time in VBA (as it's always a question how long it will be supported) and concentrate to learn VB.NET.
Happy learning, - alfred -
