VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
VBA and toolbar
3 REPLIES 3
185 Views, 3 Replies
VBA and toolbar
HI
In our mnu file we start an VBA routine this way
ID_ArmKontroll [_Button("Kontroll av valgte armeringsposter",
Armcheck.bmp, Armcheck.bmp)]^C^C^P(COWIbyggmenysti)(vl-vbaload (vba
"Armering"))(vl-vbarun "ArmeringKMacro.ArmeringUtilities")
But this will not start if enter is pushed as usually with last command.
Can anyone show me this is done.
bhl
3 REPLIES 3
bhl,
Try putting your VBA load/run commands inside of a "lisp wrapper" to make
them repeat.
Put lisp code similar to that below into your "acaddoc.lsp" file. Create the
"acaddoc.lsp" if you don't have one (see help)
Change your tool button to run the new lisp function "RunMyVBA" (as shown
below). The command should repeat (Acad 2004 or less) like any other native
command.
HTH,
Gary
(defun C:RunMyVBA ()
(vl-vbaload "C:\\YourDirectory\\YourVBAProgram.dvb")
(command "-vbarun" "YourMacroName")
(princ)
);end function "RunMyVBA"
in addition does your vba code use SendCommand anywhere? that
will end up being your last command..
"Gary McMaster" wrote in message
news:4883172@discussion.autodesk.com...
bhl,
them repeat.
command.
HTH,
Gary
(princ)
We use something like this
(vl-vbarun "YourVBAProgram.dvb!vbaname.modulename.macroname")
(princ)
This will autoload your macro as long as it is in your path and allow
you to just hit return to rerun the macro. the other way will work but
will only reissue the "-vbarun" command and not your program.
David Urban, P.E.
Project Engineer
Pape-Dawson Huffcut Engineers, Inc.
7800 Shoal Creek Blvd. Suite 253 East
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
durban@pape-dawson.com
> bhl,
> them repeat.
> command.
> HTH,
> Gary
> (princ)
David Urban, P.E.
Project Engineer
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
”Boost
