I just move on Autocad 2014 64bit Version.
I had before macro (VBA) which worked very well on Autocad 2012 32bit Version.
I'm not developper designer and I just do not understand much about the VBA code ...
My macro does not work and I saw that there were differences between the 32bit version and the 64bit version?
does anyone know the differences that currently the code?
Thank you for your answers and sorry for my English very French ... 😉
It is really not possible for anyone to say what makes your 32-bit VBA code stop working in 64-bit VBA environment without knowing/seeing what the code does and what software component the code uses, other than the fact you already know: VBA code may stop working when moving to 64-bit VBA and has to be modified accordingly.
A bit more technical aspect: you must remove/repalce all the 32-bit depedent code, if you know how to
Norman Yuan
The most common problem I have run into is HWND32 / HWND. In the object browser search for 32. Any of the objects that have a 32 bit counter part can be the issue.
