Disclaimer!!! No error checking in this example!
Dim aObject As AcadEntity
Dim Point As Variant
'select the Mtext
ThisDrawing.Utility.GetEntity aObject, Point, "Select an entity"
'check ObjectName property for MText
If UCase(aObject.ObjectName) = "ACDBMTEXT" Then
'cast object to proper data type
Dim oMText As AcadMText
Set oMText = aObject
'display the text string in a MsgBox
MsgBox oMText.TextString
That should do it. Let me know if you need further help.
Joe
joesu@worldnet.att.net
