I want to write a vba code in excel that picks up un text from a cell in an excel worksheet and finds it on an autocad drawing.
here is my code:
Sub FindTextOnAcad()
Dim Acad As acadapplication
Dim acadfile As String
acadfile = myfile.dwg
ActiveWorkbook.FollowHyperlink acadfile
Set Acad = GetObject(, "autocad.application")
Acad.ActiveDocument.sendcommand("find" & vbCr)
End Sub
This works well and opens the "Find" dialogue box in the acad drawing so I can imput the text from excel manually.
But what I need is to have vba directly find the required text without opening the "find" dialogue box
I tried the following: Acad.ActiveDocument.modelspace.find but it doesnt work
Thanks in advance for any suggestion
Almaroun
Solved by almaroun. Go to Solution.
Solved by RICVBA. Go to Solution.
use SelectionSet object methods to group all TEXT objects
here's a quick code you can adapt to your needs
Option Explicit Sub FindText() '------------------------------------------------------- 'Texts objects searching Dim myText As AcadText Dim ntexts As Integer, iText As Integer Dim myString As String Dim gpCode(0 To 1) As Integer Dim dataValue(0 To 1) As Variant Dim ssetObj As AcadSelectionSet myString = "mytext" ' text to find. here you can also use wild characters like "*mytext" or "*mytext*" 'selecting texts objects in the active drawing gpCode(0) = 0: dataValue(0) = "TEXT" ' here you can also use "TEXT,MTEXT" to pick up both object types gpCode(1) = 1: dataValue(1) = myString On Error Resume Next Set ssetObj = ThisDrawing.SelectionSets.Item("TextSset") If Err <> 0 Then Set ssetObj = ThisDrawing.SelectionSets.Add("TextSset") Else ssetObj.Clear End If On Error GoTo 0 ssetObj.Select acSelectionSetAll, , , gpCode, dataValue 'handling texts object found ntexts = ssetObj.Count For iText = 0 To ntexts - 1 ' do your stuff here ' for instance I'm listing all textstrings of the found objects Set myText = ssetObj.Item(iText) MsgBox ("Found :" & myText.TextString) Next iText '------------------------------------------------------- End Sub
bye
I modified the code slightly; I believe it's a bit cleaner:
replace "Dim ntexts As Integer, iText As Integer" and "Dim myText As AcadText" with "Dim AcadEnt As AcadEntity"
replace everything after " 'handling texts objects found" with:
For Each AcadEnt In ssetObj ' Do stuff in here; the text string can be accessed with AcadEnt.TextString MsgBox("Found : " & AcadEnt.TextString) Next AcadEnt
This eliminates the clunky counting, which should fix your issue.
@Ravi3689 wrote:Hi,
I am getting error in this Line.
Type Mismatch.
Ravi
I am new to Autocad and am trying to achieve a very similar objective. I want to change the text of a tag in an attribute so I can generate unique drawings from a generic template.
I am trying the supplied code in the post here but am getting stuck on the following line:
The ssetObj is set to "nothing" when the line above is executed. It is as if no block and/or tag and text is selected.
Any help is appreciated!
Did you include the line prior to that line? e.g. "On Error Resume Next"? Under normal execution, if the named selectionset doesn't exist, it skips to the next line and adds the selectionset.
