VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Using VBA FindFile to find filenames with spaces in it.
2 REPLIES 2
1894 Views, 2 Replies
I'm trying to use this code (by Mr. Collin French circa 1999/2000) to search
the autocad support paths to find autocad files. It works fine if the file
name doesn't have a space in it. Does anyone have any ideas on how to have
it find files with spaces in them also? Or another method/code to find files
in VB/VBA? I've tried using Chr$(34) to add "quotes" to the filename but
that still fails.
thanks in advance,
Doug Cochran
3. A FindFile() function for VBA applications
This code has been provided by Mr Collin French on the
news://adesknews.autodesk.com/autodesk.autocad.customization.vba
newsgroup.
The code shown here has been modified in format only
to fit within the confines of the newsletter format.
'----FindFile----------------------------------------
' This function looks for the specified filename in
' the current directory, the current drawing's
' directory, any of AutoCAD's support paths, and the
' directory ACAD is running from. If it finds
' the file, it will return the full path+filename.
' If not, it will return an empty string. If the
' specified filename includes any backslashes ( \ ),
' it is assumed that it's a full path+filename
' which must be checked to see if it exists, rather
' than searching amongst AutoCAD's paths. This
' function does not really work with wildcards. If it
' finds a file which matches the filespec, it
' will return the path plus the original filespec,
' eg. C:\*.bat, rather than C:\Autoexec.bat .
Public Function FindFile(FileName As String) As String
Dim Path As String 'holds path to check
Dim SupportPath As String 'copy of ACAD's support paths
Dim Pos As Integer 'position within SupportPath of separator
'----if supplied name has embedded '\' assume it is full path+filename
If InStr(1, FileName, "\") > 0 Then 'look for embedded backslash
FindFile = FileName 'copy supplied path+filename for result
On Error Resume Next 'in case of disk error
'if doesn't exist, change result to ""
If Dir$(FileName) = "" Then FindFile = ""
If Err Then FindFile = "" 'if some file error, indicate failure
Exit Function 'return result to calling routine
'----check in current directory---------------------
'construct path+filename to check
FindFile = CurDir$ & "\" & FileName
'if exists, return it as the result
If Dir$(FindFile) <> "" Then Exit Function
'----check in drawing's directory-------------------
'in ACAD 14.01, same as ThisDrawing.Path
Path = ThisDrawing.FullName
'ensure not a new, unnamed drawing
If Path <> "" Then
'chop drawing name from end of 'path'
Path = Left$(Path, Len(Path) - Len(ThisDrawing.Name))
FindFile = Path & FileName
'----check ACAD's support directories----------------
'copy of support paths
SupportPath = ThisDrawing.Application.Preferences.SupportPath
'ensure has trailing '\'
If Right$(SupportPath, 1) <> "\" Then SupportPath = SupportPath & "\"
'check each one until none left
Do While Len(SupportPath) > 0
'look for separator between paths
Pos = InStr(1, SupportPath, ";")
'if found a separator character...
If Pos > 0 Then
'...extract path before it
Path = Left$(SupportPath, Pos - 1)
'no separator, so...
Else
'...must be last path in SupportPath
Path = SupportPath
'make sure has trailing backslash
If Right$(Path, 1) <> "\" Then Path = Path & "\"
'if exists, return as result
'chop off path just checked
SupportPath = Right$(SupportPath, Len(SupportPath) - Len(Path))
'probably separator still there
If Left$(SupportPath, 1) = ";" Then
'chop it off too
SupportPath = Right$(SupportPath, Len(SupportPath) - 1)
'check next path in SupportPath
Loop
'----check in AutoCAD's program directory-------------
'get path to ACAD.EXE
Path = ThisDrawing.Application.Path
'----can't find file, return empty string to indicate failure
FindFile = ""
End Function
'----TestFindFile----------------------------------------
' This routine is used to test the FindFile function.
' It brings up an InputBox so the user can
' enter the name of a file to check for, calls FindFile(),
' then displays the result in a MsgBox.
Public Sub TestFindFile()
Dim res As String 'holds the result of function calls
Dim msg As String messages to present to user
'----prompt user for filename to test
msg = "Enter the filename you want to try with the FindFile function." &
vbCrLf & vbCrLf
msg = msg & "FindFile will look in the current directory, the directory" &
vbCrLf
msg = msg & "containing the current drawing (if any), AutoCAD's support" &
vbCrLf
msg = msg & "directories, and the directory AutoCAD is running from." &
vbCrLf
res = InputBox(msg, "Testing FindFile", "acad14.cfg")
'----use the FindFile function retrieve full path+filename
'if user pressed 'Cancel', res = ""
If res <> "" Then
'search for file
res = FindFile(res)
'FindFile returns "" if can't find file
If res = "" Then
'compose message to that effect and
msg = "Couldn't find that file."
'tell user what happened
MsgBox msg, vbInformation, "Testing FindFile"
Else
'FindFile returned full path+filename
msg = "Found that file in: '" & res & "'."
'show result to user
End Sub
2 REPLIES 2
Public Declare Function SearchPath Lib "kernel32" Alias "SearchPathA" _
(ByVal lpPath As String, _
ByVal lpFileName As String, _
ByVal lpExtension As String, _
ByVal nBufferLength As Long, _
ByVal lpBuffer As String, _
ByVal lpFilePart As String) As Long
Public Const MAX_PATH = 260
Public Function FindFile(sFileName As String, Optional sPath As String =
vbNullString) As String
Dim retVal As Long, lpBuffer As String * MAX_PATH
retVal = SearchPath(sPath, sFileName, vbNullString, MAX_PATH, lpBuffer,
vbNullString)
FindFile = IIf(retVal, Left(lpBuffer, retVal), "ERROR")
End Function
Example
FindFile("autoexec.bat")
this code is from http://code.acadx.com/
"Doug Cochran" wrote in message
news:B36C85FB1F3CF1505FEFEDFBDF5719CA@in.WebX.maYIadrTaRb...
search
file
have
files
> that still fails.
> thanks in advance,
> Doug Cochran
> newsgroup.
> End If
> If Path <> "" Then
> End If
> If Pos > 0 Then
> Else
> Path = SupportPath
> End If
> 'chop it off too
> End If
> Loop
> FindFile = ""
> End Function
> vbCrLf & vbCrLf
> vbCrLf
> vbCrLf
> vbCrLf
> If res <> "" Then
> 'search for file
> res = FindFile(res)
> If res = "" Then
> Else
> End If
> End If
> End Sub
Short, Sweet and it worked!!! Thanks!
"Humberto Guerrero Obando" wrote in message
news:1470C28CF021D1632A0AAC0AF73390F6@in.WebX.maYIadrTaRb...
lpBuffer,
> vbNullString)
> End Function
> Example
> search
> file
> have
> files
but
> > that still fails.
> > thanks in advance,
> > Doug Cochran
> > newsgroup.
> > End If
> > If Path <> "" Then
> > End If
> > If Pos > 0 Then
> > Else
> > Path = SupportPath
> > End If
> > 'chop it off too
> > End If
> > Loop
> > FindFile = ""
> > End Function
> > vbCrLf & vbCrLf
directory"
> > vbCrLf
support"
> > vbCrLf
> > vbCrLf
> > If res <> "" Then
> > 'search for file
> > res = FindFile(res)
> > If res = "" Then
> > Else
> > End If
> > End If
> > End Sub
”Boost
