I installed VS 2010 Express and then installed ObjectARX SDK 2013.
I can start a project, but in myCommands.vb I get the message above. It's going to be difficult to continue if any commands I create have a 0% chance of working.
Does anyone know why I would get this error even though I am able to start a project using the AutoCAD Plug-in.
I have already uninstalled and re-installed VisualStudio and ObjectArx.
Any ideas?
Solved by andrewpuller3811. Go to Solution.
Hope you added these references:
Imports Autodesk.AutoCAD.Runtime '<-- this one is to call CommandMethod
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
~'J'~
Yep, all the references are there. Any other ideas?
I double-checked my folders for acmgd.dll and acad.exe and those are correct.
does _NETLOAD tell you any problems?
- alfred -
Have you got a reference to AcCoreMgd.dll ?
That was it, ACCoremgd.dll. I loaded that reference and I'm off and running.
Thanks for the help!
How were you able to compile your project with success?
Ohh, or haven't you set "Option Strict" active? If so, set it to yes and you will get errors while writing code and at least when compiling your source. That saves you a lot of time!
- alfred -
Thanks.
