OK, if that's the case, is there a way to prevent the dialog that
requests alternative to bigfonts from popping up every time I open the dwg?
Cheers
Dave F.
Bob wrote:
> i don't believe you can turn it off.
> "Dave F." wrote in message
> news:5648889@discussion.autodesk.com...
> Hi
> I'm using 2007.
> I want to amend existing TextStyles so that the 'Use Big Font' switch in
> the Texstyle dialog is turned off.
> From the Help it says for the .bigfontfile property that 'This property
> cannot be set to NULL or an empty string.'
> How do I turn it off?
> Thanks for any help
> Dave F.
