VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
thavasi1982
307 Views, 3 Replies
Trim
How to trim the object using VB coding
STM
3 REPLIES 3
truss_85
in reply to: thavasi1982
There is no specific code for trimming.
You can use send command to trim object.
thavasi1982
Thanks for your reply.
How to use sendcommand for crossing option as the crossing option does not accept co-ordinates. Instead it asks to pick a point on screen.I have attached a drawing, I have tried many ways to get the final output as you seen in the drawing but i cannot.
STM
Maybe an idea to get the objects, try to .IntersectWith and manually replace the last coordinate with the InterSect-Point? The last coordinate can be determined by the Clicked Points (I think you use GenEntity?)
Util..getentity Object1, PickPoint1
Util..getentity Object2, PickPoint2
IntersectPoint=object1.IntersectWith (Object2,acExtendNone)
IntersectPoint( [0-2] ) has the coordinates...
Peter
”Boost
