Mark, don't know if it helps in your case (vba), but you could try and
create a new acad session and do the loop there.
Once finished, just close the session.
But of course, it could get messy doing that from VBA.
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
(sorry, phony e-mail, SPAM made me do it)
"Mark Propst" wrote in message
news:40a7dfd9_2@newsprd01...
> Thanks for the confirmation,
> In this case I just wanted to auto set the ProjectName on several folders
> and their subfolders.
> Its easy enough to just open the dwgs in a loop as go the dbx route, just
> wanted to confirm that I wasn't just 'not' seeing it. I know that's a
> double negative but it still seems the right way to say it!?!
> The obvious downside of having to open in the editor to do whatever..is
> tying up the 'hosting' application - the session of acad from which the
call
> to the routine was made. (assuming vba)
> But it seems that's the case with dbx as well, If i start a dbx loop, it
> still seems to capture acad's attention and I can print messages to
command
> line or such but I haven't figured a way to make a loop "run in the
> background" - such that the user could go back to editing the current
> drawing while the loop is doing it's thing....
> I guess that should be a whole different thread.
> Thanks again for the info, Tony
> Mark
> "Tony Tanzillo" wrote in message
> news:40a6f72e$1_3@newsprd01...
> > Since GetVariable and SetVariable are methods of AcadDocument,
> > they only work on AcadDocuments (they're just wrappers for
> > the ObjectARX counterpart of the (getvar) and (setvar) LISP
> > functions). So there's no method for getting/setting system
> > variables stored in drawings that are accessed directly via
> > ObjectDBX.
