I am not sure if there is a correct way to do this but I can share with you
how I do it. When I enter the block of code that will be executing a
statement to the command line, I will always force a VbCrLf infront of the
string I am using as a prompt. I have also forced a VbCrLf at the prompt
just to before and after send commands and other routines that make the
'command:' string pop-up. It works. There may be better ways of doing
this.
Good Luck
CB
wrote in message news:5573799@discussion.autodesk.com...
As I execute some VBA code with prompts I get the "Command: " before my
prompts. This is an example as it executes:
Command: mr
Enter Room Label Line 3: five
Command: Enter Room Label Line 2: ten
Command: Enter Ceiling Text :fifteen
How do a get rid of the "Command: " at the beginning of each line?
David
