VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Store info in registry, INI or XML
4 REPLIES 4
201 Views, 4 Replies
Hi I've been using the registry to store/retrieve info between Acad sessions. But searching this NG there seems to be a movement against this. (Hello, Mr. Tuersley). Instead, so I read, I should be using ini files via win32api or XML. What are the reasons for this? Faster/slower, easier? Are there any examples to get me going? I've used the API a couple of times, but XML is new to me. Any help will be greatfully received TIA Dave F.
4 REPLIES 4
Hello Dave :) Let's set the record straight, I'm not against using the registry. The registry should be used for storing a value that will almost never change such as the location of your backend database. The registry shoud never be used to store revolving data such as user options for your program. The reasoning is simple - the registry is already too large, too slow and dependent upon the logged in user's rights as to which sections can be read/written. Of the two INIs are the least favorite but usually the easiest for programmers to integrate with. XML is the better choice but not the easiest to pickup and run with. I'm out of the office today, but tomorrow I will post an XML exmple for you. Until then, there have been some examples already posted here. Mike
Dave I have slogged through saving my data to an XML it wasn't very easy to learn about it but once I figured it out it is very easy to read and navigate the file. there was no help in the VBA system so you have to go to the MS site to find it and it is not geared for VBA so it was a bit of work to figure it out. What helped me is to find the XML notepad program which I set up a dummy file to help me figure out how I wanted to format my data and then try and program it. here is a small snip it of my code. it is used to save and retrieve my UDT which is used in multiple drawings. Option Explicit Dim oDoc As DOMDocument Dim oAlg As IXMLDOMElement Dim oSta As IXMLDOMElement Dim oLat1 As IXMLDOMElement Dim oLat2 As IXMLDOMElement Dim oRoot As IXMLDOMElement Dim oStation As IXMLDOMAttribute Public Sub Save_toXML() Set oDoc = Nothing Set oDoc = New DOMDocument oDoc.async = False On Error Resume Next oDoc.Load (fXMLFile) Set oRoot = oDoc.documentElement 'If Err.Number <> 0 Then oDoc.resolveExternals = True If oDoc.parseError <> 0 Then ' Create processing instruction and document root Set oAlg = oDoc.createProcessingInstruction("xml", "version='1.0'") Set oAlg = oDoc.insertBefore(oAlg, oDoc.childNodes.Item(0)) ' Create document root Set oRoot = oDoc.createElement("Project_" & CStr(Project)) Set oDoc.documentElement = oRoot ' oRoot.setAttribute "xmlns:dt", "urn:schemas-microsoft-com:datatypes" 'Else 'Set oRoot = oDoc.documentElement End If Err.Clear Dim events As Variant, alignname As String Dim x As Integer, name As String, name2 As String name = Replace(algname, " ", "_") alignname = "//Project_" & CStr(Project) & "//" & name Set oAlg = oDoc.selectSingleNode(alignname) name2 = oAlg.baseName If name2 <> "" Then For x = oAlg.childNodes.length - 1 To 0 Step -1 Set oSta = oAlg.childNodes.Item(x) If Left(oSta.baseName, 3) = "Sta" Then oAlg.removeChild oSta End If Next x Else Set oAlg = oDoc.createElement(name) oRoot.appendChild oAlg End If oAlg.setAttribute "ALGNUMBER", align.Number For x = LBound(AlignPt, 1) To UBound(AlignPt, 1) Set oSta = oDoc.createElement("Sta" & Format(AlignPt(x).station, "0.00")) oAlg.appendChild oSta Write_XMLStation oSta, oDoc, AlignPt(x) Next x ' Save xml file oDoc.Save fXMLFile Set oDoc = Nothing End Sub Public Function Load_fromXML() As Boolean Dim nodes As IXMLDOMNode Set oDoc = Nothing Set oDoc = New DOMDocument oDoc.async = False On Error Resume Next oDoc.Load (fXMLFile) 'Set oRoot = oDoc.documentElement 'If Err.Number <> 0 Then oDoc.resolveExternals = True If oDoc.parseError = 0 Then Dim alignname As String Dim x As Integer, name As String, name2 As String, y As Integer x = -1 name = Replace(algname, " ", "_") alignname = "//Project_" & CStr(Project) & "//" & name Set oAlg = oDoc.selectSingleNode(alignname) Debug.Print Err.Number name2 = oAlg.baseName If name2 <> "" Then If oAlg.getAttribute("ALGNUMBER") = align.Number Then ReDim AlignPt(100) For y = oAlg.childNodes.length - 1 To 0 Step -1 Set oSta = oAlg.childNodes.Item(y) If Left(oSta.baseName, 3) = "Sta" Then x = x + 1 Read_XMLStation oSta, AlignPt(x) Load_fromXML = True End If Next y ReDim Preserve AlignPt(x) End If End If End If Set oDoc = Nothing End Function Private Sub Write_XMLStation(oSta As IXMLDOMElement, oDoc As DOMDocument, temp As junctions) Dim oLat1 As IXMLDOMElement, oLat2 As IXMLDOMElement oSta.setAttribute "Station", temp.station oSta.setAttribute "Event", temp.Event oSta.setAttribute "Direction", temp.direction oSta.setAttribute "DirectionUP", temp.DirectionUP oSta.setAttribute "Easting", temp.Easting oSta.setAttribute "Northing", temp.Northing oSta.setAttribute "Pipesize", temp.pipesize oSta.setAttribute "PipesizeUP", temp.PipesizeUP oSta.setAttribute "Flowline", temp.FlowLine Set oLat1 = oDoc.createElement("Lateral1") oSta.appendChild oLat1 oLat1.setAttribute "name", temp.Lateral1.name oLat1.setAttribute "Station", temp.Lateral1.INTStation oLat1.setAttribute "count", temp.Lateral1.count oLat1.setAttribute "Direction", temp.Lateral1.direction oLat1.setAttribute "eEast", temp.Lateral1.EndEasting oLat1.setAttribute "eNorth", temp.Lateral1.EndNorthing oLat1.setAttribute "eSta", temp.Lateral1.EndStation Set oLat2 = oDoc.createElement("Lateral2") oSta.appendChild oLat2 oLat2.setAttribute "name", temp.Lateral2.name oLat2.setAttribute "Station", temp.Lateral2.INTStation oLat2.setAttribute "count", temp.Lateral2.count oLat2.setAttribute "Direction", temp.Lateral2.direction oLat2.setAttribute "eEast", temp.Lateral2.EndEasting oLat2.setAttribute "eNorth", temp.Lateral2.EndNorthing oLat2.setAttribute "eSta", temp.Lateral2.EndStation End Sub Private Sub Read_XMLStation(oSta As IXMLDOMElement, temp As junctions) Dim oLat1 As IXMLDOMElement, oLat2 As IXMLDOMElement With temp .station = oSta.getAttribute("Station") .Event = oSta.getAttribute("Event") .direction = oSta.getAttribute("Direction") .DirectionUP = oSta.getAttribute("DirectionUP") .Easting = oSta.getAttribute("Easting") .Northing = oSta.getAttribute("Northing") .pipesize = oSta.getAttribute("Pipesize") .PipesizeUP = oSta.getAttribute("PipesizeUP") .FlowLine = oSta.getAttribute("Flowline") Set oLat1 = oSta.firstChild .Lateral1.name = oLat1.getAttribute("name") .Lateral1.INTStation = oLat1.getAttribute("Station") .Lateral1.count = oLat1.getAttribute("count") .Lateral1.direction = oLat1.getAttribute("Direction") .Lateral1.EndEasting = oLat1.getAttribute("eEast") .Lateral1.EndNorthing = oLat1.getAttribute("eNorth") .Lateral1.EndStation = oLat1.getAttribute("eSta") Set oLat2 = oSta.lastChild .Lateral2.name = oLat2.getAttribute("name") .Lateral2.INTStation = oLat2.getAttribute("Station") .Lateral2.count = oLat2.getAttribute("count") .Lateral2.direction = oLat2.getAttribute("Direction") .Lateral2.EndEasting = oLat2.getAttribute("eEast") .Lateral2.EndNorthing = oLat2.getAttribute("eNorth") .Lateral2.EndStation = oLat2.getAttribute("eSta") End With End Sub Dave F. wrote: > Hi > > I've been using the registry to store/retrieve info between Acad sessions. > But searching this NG there seems to be a movement against this. (Hello, Mr. > Tuersley). > > Instead, so I read, I should be using ini files via win32api or XML. > > What are the reasons for this? Faster/slower, easier? > > Are there any examples to get me going? > I've used the API a couple of times, but XML is new to me. > > Any help will be greatfully received > > TIA > Dave F. > >
Here's a quick down-n-dirty example of using xml. It is pretty much the same as an ini at this point, but hopefully you can experiment and/or read up on the topic to see the greater value of it. If I get time. I may post something more detailed. For now; 1. In NotePad, paste this text: C:\My Files\My Directory Mike Tuersley 2004-03-05 2. Save the file as DEFAULTS.XML 3. Open a vba module and paste in this code: Sub test() Dim xDoc As DOMDocument Dim xRoot As IXMLDOMElement Dim xNode As IXMLDOMElement Dim oChild As IXMLDOMElement Dim lCnt As Long Set xDoc = New DOMDocument xDoc.Load "C:\Defaults.xml" DoEvents Set xRoot = xDoc.documentElement For Each xNode In xRoot.childNodes If xNode.baseName = "defaults" Then For lCnt = 0 To xNode.childNodes.Length - 1 Set oChild = xNode.childNodes.Item(lCnt) MsgBox oChild.baseName & ": " & oChild.text Next Exit For End If Next End Sub 4. Add a reference to Microsoft XML [4.0 or better] and change the xDoc.Load line to point to the file you saved in step 2. In closing, notice how the xml file contains the data type so it is passing more than just values. This example does not go into the data types, but its not hard to figure out how to do it. Good luck, Mike
Thanks Mike & David, for that. I shall look into it Dave F. "Mike Tuersley" wrote in message news:t2ff61u9i7bo.jj678hrp2ijd$.dlg@40tude.net... > Here's a quick down-n-dirty example of using xml. It is pretty much the > same as an ini at this point, but hopefully you can experiment and/or read > up on the topic to see the greater value of it. If I get time. I may post > something more detailed. For now; > > 1. In NotePad, paste this text: > > > > C:\My Files\My Directory > Mike Tuersley > 2004-03-05 > > > > 2. Save the file as DEFAULTS.XML > > 3. Open a vba module and paste in this code: > > Sub test() > Dim xDoc As DOMDocument > Dim xRoot As IXMLDOMElement > Dim xNode As IXMLDOMElement > Dim oChild As IXMLDOMElement > Dim lCnt As Long > Set xDoc = New DOMDocument > xDoc.Load "C:\Defaults.xml" > DoEvents > Set xRoot = xDoc.documentElement > For Each xNode In xRoot.childNodes > If xNode.baseName = "defaults" Then > For lCnt = 0 To xNode.childNodes.Length - 1 > Set oChild = xNode.childNodes.Item(lCnt) > MsgBox oChild.baseName & ": " & oChild.text > Next > Exit For > End If > Next > End Sub > > 4. Add a reference to Microsoft XML [4.0 or better] and change the > xDoc.Load line to point to the file you saved in step 2. > > In closing, notice how the xml file contains the data type so it is passing > more than just values. This example does not go into the data types, but > its not hard to figure out how to do it. > > Good luck, > > Mike
”Boost
